2006 Central locking query
- justintime441
07 Mar 2021 03:21 #233499
by justintime441
2006 Central locking query was created by justintime441
Hello everyone!
I have a JB43 Jimny with a very weird and mildly infuriating problem. The Central locking is intermittent, half the time it works and the other half it doesn't. The weird issue is that once the key is inserted into the ignition (not turned to accessory or on position) it begins working as it should.
Things I've tried:
Thanks for reading and helping out!!
Things I've tried:
- Pulled the door card and sprayed contact cleaner in the motor connection and gave it a few wiggles
- Ensured that the motor was receiving constant power
- Checked with the service manual to ensure wiring is correct and had not been tampered with in the past (I only checked the motor wiring, not sure where the wires go after they pass through the door)
07 Mar 2021 07:24 #233500
Replied by yakuza on topic 2006 Central locking query
Any difference in the response when you turn the key in the door lock, push the button at the drivers door, or pull the knob at the window sill?
I Think mine Has Some sort of blocking when lights are left on, or the Doors is not shut properly.
- justintime441
08 Mar 2021 02:49 #233529
by justintime441
Replied by justintime441 on topic 2006 Central locking query
I've tested using both keys.. both doors locked (all lights off) and manually using the pull knob. Only operable when key in ignition. Just can't wrap my head around why it works when key is simply put in the ignition
- Thank you received: 2004
08 Mar 2021 05:04 #233533
Replied by Lambert on topic 2006 Central locking query
It's electrics so not my comfort zone but I think there's a module under the dashboard which controls the system so that it knows if a door is open etc it would be worth checking the wiring to that. Is someone able to confirm the existence and location of this?
The following user(s) said Thank You: justintime441
- justintime441
12 Mar 2021 00:32 #233667
by justintime441
13 Mar 2021 08:34 #233701
by RainerK
Replied by RainerK on topic 2006 Central locking query
I would then also check the electricity consumption. If the beeper beeps all the time maybe some module does not go to sleep and slowly drains your battery and after two weeks it might not start.
Time to create page: 0.101 seconds
