Best material for workshop worktop.
06 Mar 2021 10:54 #233481 by Roger Fairclough
The worktops in my workshop have seen better days so I am looking at 2 layers of 18mm plywood topped with a decent laminate.
Unless you guys can point me in another diection?
I have tried kitchen worktops but the laminates are invariably cheap and nasty.
Roger
06 Mar 2021 12:42 #233482 by Lambert
My side bench is 25mm block board and seems to take the abuse. My main bench is just plywood and covered in welding burns and gouge marks and everything but it's sacrificial so I don't care. The base is 3x6 tanalised posts glued and bolted together with threaded bar. If I had the headroom to swing it would take a full overhead blow from my big sledgehammer.
06 Mar 2021 15:43 #233487 by Scimike
Mine are covered in galvanized sheet steel simply fixed down with wood screws. I don't matter what's underneath, cheap and strong is all you need, the top is indestructible.
06 Mar 2021 16:48 #233488 by Roger Fairclough
Thank you both for your input.
Scimike, how thick is your galv. steel sheet?
Roger
06 Mar 2021 17:43 #233489 by Scimike
Hi Roger,
I use 1.5mm that I get cut to manageable sizes at a local metal firm. I have one stand alone small bench that I build engines on, that's 3mm thick, but the wood below is a very thin, so I am over compensating with this one....
06 Mar 2021 22:32 #233494 by HUN
I use 3mm sheet metal on top of 18mm OSB. Easy to clean, durable and suitable for hot works.
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
