fitting anual hubs should be a doddle right? ahhhhhhh!
23 Feb 2021 19:44 #233170
by Busta
Replied by Busta on topic fitting anual hubs should be a doddle right? ahhhhhhh!
Take a hub off and see if you can turn the driveshaft, and if that makes the propshaft spin.
- Roger Fairclough
- Thank you received: 225
24 Feb 2021 10:42 #233206
by Roger Fairclough
Replied by Roger Fairclough on topic fitting anual hubs should be a doddle right? ahhhhhhh!
Or the other way round.
Roger
Roger
24 Feb 2021 13:35 #233212
Replied by mlines on topic fitting anual hubs should be a doddle right? ahhhhhhh!
What fitment hubs do you have?
1. Vitara fitment on a jimny - need a spacer ring
2. Jimny fitment on a jimny - do not need a spacer ring.
- roughnready
- Thank you received: 1
24 Feb 2021 15:18 #233223
by roughnready
Replied by roughnready on topic fitting anual hubs should be a doddle right? ahhhhhhh!
OK, found the problem, ticking sound was the oversized toothed doughnut on the new hubs spinning baggily on the end of the half shaft. Right number of teeth, just hole about 2mm too large. Either i'ts manufacturer mistake or previous owner fitted some none standard shafts. Think very carefully before buying Tyrex TY08571.Will have to wait for dealer to get back to me with a fix. Oh well, A few more days work not getting done on this small holding. Wishing I'd drilled and sunk a bolt through the original hubs now.
- Johnniehec
- Thank you received: 56
24 Feb 2021 16:28 - 24 Feb 2021 18:45 #233228
by Johnniehec
Replied by Johnniehec on topic fitting anual hubs should be a doddle right? ahhhhhhh!
Just put the original vac hubs back on in the locked position, no need to fuss about drilling holes in them. I've been competing for four years with mine like that and another four years in my previous Jimny.
Last edit: 24 Feb 2021 18:45 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
24 Feb 2021 18:12 - 24 Feb 2021 18:46 #233236
by Busta
The advantage of the screw method is you don't even need to remove the hub. With a 20mm self tapping screw it takes just a couple of seconds. No fussing about at all!
Last edit: 24 Feb 2021 18:46 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
Time to create page: 0.354 seconds
