fitting anual hubs should be a doddle right? ahhhhhhh!
- roughnready
- Thank you received: 1
17 Feb 2021 14:20 #232898
by roughnready
Ok, found I had no four wheel drive, so fitted some Tyrex freewheeling hubs. Disconnected and capped the vaccuum pipes. Didn't disconnect sensor under battery as getting cold and I wasn't sure I had the right bit. Should be hunky dory right? Still no drive to the front wheels whether set to 4x4 or 4x2. When in gear and front jacked up, wheels spin freely by hand, except passenger side makes a ticking sound as it spins. As you can no doubt tell, I am to mechanicing as Mary Berry is to shot putting, so helpful suggestions would be apprecitaed. Ceheers
17 Feb 2021 14:56 #232899
by Busta
Replied by Busta on topic fitting anual hubs should be a doddle right? ahhhhhhh!
Ticking noise could be a broken CV.
It's always best to trouble shoot the vacuum system before ditching it. It's simple and easy to maintain.
- Roger Fairclough
- Thank you received: 225
17 Feb 2021 15:32 #232900
by Roger Fairclough
Replied by Roger Fairclough on topic fitting anual hubs should be a doddle right? ahhhhhhh!
Jack the front axle off the ground. Put car into 4 wheel drive mode. Lock in hubs. Try to turn each front wheel by hand with other wheel chocked. Wheel should not rotate. If it does, drive has been interrupted. Do both sides. Probably one side defective, but you need to check free wheeling hubs for correct operation. but you need to check drive from T/box. Jack up front with both wheels off the ground. Make sure car stable and safe. Use axle stands or similar. In 4 wheel drive propshaft should not rotate. Release 4 wheel drive, propshaft should rotate. If it rotates when in 4 wheel drive, you have t/box problem.
- Johnniehec
- Thank you received: 56
19 Feb 2021 22:42 - 19 Feb 2021 22:50 #233021
by Johnniehec
Replied by Johnniehec on topic fitting anual hubs should be a doddle right? ahhhhhhh!
You only need to jack one front wheel off the ground. Select 4wd, switch hubs to 4x4 or locked and jack either front wheel off the ground. If you can rotate the wheel by hand somethings wrong. Looking at the front prop while turning the wheel by hand, if it's rotating hubs are good and transfer box isn't selecting 4wd, if it's not turning one or both hubs are not locked. Then remove the hub on the jacked wheel and try to rotate the half shaft, you'll need a mole grip or a big pliers if you can't turn it the other hub is locked correctly and the one you've removed wasn't locked, if you can turn it the other hub isn't locked, and the one you've removed might or might not have been locked either.
Last edit: 19 Feb 2021 22:50 by Johnniehec.
- roughnready
23 Feb 2021 17:32 #233161
by roughnready
Replied by roughnready on topic fitting anual hubs should be a doddle right? ahhhhhhh!
Brilliant that makes sense. Tried it with both wheels seperately and it looks like neither hub is making the connection as spinning freely when other wheel is on the ground. No rotating half shaft . Next question. WHY? New hubs look like substancial pieces of engineering, and when I twisted the dial off the car, the centre seemed to move in and out as expected. Starting to feel like I've missed something obvious? Other than disconnecting vacuum tubes, capping and doing a straight swap, is there anything else to this?
- Thank you received: 2004
23 Feb 2021 18:28 #233166
Replied by Lambert on topic fitting anual hubs should be a doddle right? ahhhhhhh!
You mentioned that you got a clicking noise, with the steering on full lock either way does the clicking get worse when you turn the tyre?
Time to create page: 0.174 seconds
