Outside Temperature gauge
  • Gilling Red
11 Feb 2021 15:24 #232693 by Gilling Red
Outside Temperature gauge was created by Gilling Red
Hi All after the recent cold weather my outside teperature moinitor appears to be stuck at -9'c is there anyway to rester the monitor ?
11 Feb 2021 19:42 #232702 by Lambert
Replied by Lambert on topic Outside Temperature gauge
We're supposed to be getting lower than that tonight so it might have a reset on it's own when it's morning? Otherwise I don't have any idea, sorry.
12 Feb 2021 06:43 #232712 by saxj
Replied by saxj on topic Outside Temperature gauge
Mine stops working when in low range. Which is irritating because then the aircon stops working properly and I have to override it manually.
12 Feb 2021 14:06 #232723 by Scimike
Replied by Scimike on topic Outside Temperature gauge
They never used to be on older vehicles an item that could be reset as such. They have been a Thermistor (resistance that varies with temp), much the same as the engine temperature sensor.
They are usually located about the grille area, if you can find it warm it up and see it the reading changes. If it stays put it's likely it's failed, simple to replace and even easier if you still have a warranty.
Of course this assume Suzuki have not reinvented the wheel and given you a resettable digital temperature sensor that's just tripped!
Time to create page: 0.089 seconds
