Fuel pump access hole
- justintime441
26 Jan 2021 00:12 #232188
by justintime441
Fuel pump access hole was created by justintime441
Good day to all.
I Will be removing the carpets and interior soon to line the floor with a bed liner, in preparation for some water crossings and to add a bit of sound deadening. I was thinking I could cut out the floor in order to gain access to the fuel pump in the tank in case of a later replacement. Is this possible? I haven't dropped the tank before to see how it looks or where it's located in relation to the floor. Does it use a lock ring which has to be hammered out? Or is it a couple bolts that holds the pump in?
Cheers all. **Gen 3 jimny, 2006**
26 Jan 2021 07:19 #232199
Replied by yakuza on topic Fuel pump access hole
As there is very little difference in the work involved in changing the pump from inside or outside, I would not do this.
There is also the obvious advantages from taking the tank out from underneath the car as this gives you the possibility of doing rust treatment, changing hoses, and giving you a better place on a bench to work on the tank.
The following user(s) said Thank You: justintime441
- Thank you received: 706
26 Jan 2021 15:54 #232214
Replied by jackonlyjack on topic Fuel pump access hole
Pump is held in by 8 bolts if i remember right
Personaly i would cut the hole
Yakuza does have a good point about access to sort rust out though
It's not so easy to drop the tank prop,exhaust,filler hoses all have to be removed
Then you have the bolts on tank with captive nuts.........very rusty and may snap
- justintime441
27 Jan 2021 19:52 #232272
by justintime441
Replied by justintime441 on topic Fuel pump access hole
Thanks I'm gonna look about cutting it out, my jimny doesn't have rust like others I've seen here. Caribbean weather and not close to the sea. I've also preventatively undercoated everything from the tank forward
Time to create page: 0.090 seconds
