Driving in 4wd
- Roger Fairclough
- Thank you received: 225
So how does this relate to the original question. When driving on ice or snow - there called hazards - you must look way way ahead of you. Be prepared to take evasive action and if that is a parked car or anything in your path then be prepared to accelerate as you steer.
Roger
I know where you are coming from, but you should have better braking in 4wd on slippery surfaces vs 2wd. This is down to how the brake bias is setup on a road car. With 4wd the transfer box will give yoku 50:50 spilt bias which should give more effective braking and likely to induce ABS. Due to not having the weight transfer you'd normally get on a grippy surface. There are also benefits in cornering too with 4wd in low grip scenarios.Lambert wrote: Don't forget that you don't have any more grip in 4x4 than you would in 4x2. What you have is more traction which means you can't stop any faster even though you can get going quicker. But if you are driving that fast in snow and ice that you need more traction then you are going to have problems. When it's that bad outside I look at 4x4 as a reserve, so for example if I have to climb a meaningful gradient on packed snow, not as a means of travelling at dry tarmac speed.
If you find you are going to slowly you can always speed up. In slippery conditions you can not normally easily slow down if going to fast.Barry silver SZ5 wrote: Still unsure what's best in the snow or ice, I live at bottom of a steep narrow bendy village hill , when starting to go down should I engage 4 wheel drive ? High or low ratio or switch on the hill decent mode , A previous 2 wheel drive car I just slid down and I bashed car on a bank and once in a ditch, Brought an Audi with constant 4 wheel drive and no problems , so thought the new Jimny ideal replacement, but now snowing don't want to damage it. I am not technically great but wanting to be in best settings to go down (or climb ) what can be a very slippery hill used by few drivers. Your wisdom appreciated.
You really need to judge the conditions at hand and make an informed judgement call. Brake test and feel how much grip there is and how easy the vehicle slides. This will let you know what sort of speed you can decend the hill safely at. If you need 4wd, select it before hand, don't wait until it is too late. Low range will give even more control if it is very steep and/or slippery.
Use engine braking (and HDC if you have it), but try to stay off the brake pedal and don't push the clutch in. In many ways it is no different to driving down a steep slippery muddy hill.
Experiment with it. Pay attention to the affects it has on the way the car drives, the feel of the steering, how the braking changes, the noises it makes. You should soon get an idea when it's happy and when it isn't.
- Thank you received: 81
lt's just that l am used to driving my Defender which is permanently in 4wd.
