Driving in 4wd
- Thank you received: 81
The thing is, when you get to a piece of road with no ice, do you have to disengage the 4wd only to engage it again a minute later?
How far can you drive on normal roads with the 4wd engaged, or can't you do it at all.
l am guessing corners are more of an issue. My friend who lives in High Peak leaves her gen 3 in 4wd all the time in bad weather and as far as l know it's somehow survived.
It is sadly a limitation of this type of 4wd system. And really one of the of the big benefits of something like a Land Rover Defender/Range Rover/Discovery for such conditions.lightning wrote: ln the ice and snow l have often found the need to select 4wd on our Gen 4 Jimny.
That said you should be able to gauge if you need to put it in 2wd or not. Lower speeds and gentle bends for shorter distances should be fine in 4wd. It would be longer distances, higher speeds and tighter corners that the problem or transmission wind up would occur. But do remember not to leave it in 4wd.
However if you are not confident to gauge this, then don't use 4wd on dry paved surfaces.
- Thank you received: 1983
- Groundworker
They might have a flash badge dosnt mean they the same degree of intelligence as youGroundworker wrote: I think you're wrong about breaking in snow and ice, I was driving my Isuzu Dmax to work the other morning on black ice on a notorious local 'road', tip toeing along using the gearbox to brake and had an Audi A6 up my backside the whole time, so they can obviously stop on a sixpence on black ice!!
