Re:First service after 12 months
- Bill Portland
- Thank you received: 77
23 Jan 2021 07:57 #232102
by Bill Portland
Replied by Bill Portland on topic Re:First service after 12 months
Just one point to bear in mind if you intend to service it yourself is that the bodywork inspection has to be done annually by a suzuki dealer in order to maintain the 12 year anti corrosion warranty (if its worth having).
- Thank you received: 81
23 Jan 2021 09:04 #232104
by lightning
Replied by lightning on topic Re:First service after 12 months
Ah yes l forgot about that. l will speak to the dealer to see how much it costs to get that done, it may be in that case it has to be dealer serviced, but if a more involved service is only £200 then an annual oil change and check over shouldn't be expensive.
23 Jan 2021 13:08 #232111
by Scimike
Replied by Scimike on topic Re:First service after 12 months
I would read the small print before you get hung up about the dealer body inspection warranty. It's usually a perforation warranty (a rot hole), but I've not seen the Suzuki one, so don't know for sure.
So if you service it yourself just keep the wax topped up or apply it yourself and it will be better protected than anything the dealer will offer under the warranty.
I don't like dealers, anyone noticed
23 Jan 2021 13:15 #232112
by lightning
Well yes, one thing was when l took it in the average fuel consumption was at 42mpg and when l got it back it was at 36mpg so l do wonder how they managed to get it down that much.
That must have been some enthusiastic road test that they did in the vehicle.
23 Jan 2021 14:09 #232113
Replied by Soeley on topic Re:First service after 12 months
They probably left it running on tick over for ages to get it up to temp, mpg soon drops that way.
- Roger Fairclough
- Thank you received: 225
24 Jan 2021 18:12 #232153
by Roger Fairclough
Replied by Roger Fairclough on topic Re:First service after 12 months
Lightning.
If you have your fuel consumption set to restart each time you fill up and the new mileage when you took it in for it's service was low, then it would not take much energetic driving to drop from 42 mpg to 36 mpg. Also 42 mpg is a good figure and would indicate a more sedate driving style than a mechanic who is testing the vehicle to see that it will do what it is supposed to do.
Roger
Roger
Time to create page: 0.554 seconds
