Re:First service after 12 months
22 Jan 2021 17:47 - 22 Jan 2021 17:49 #232084 by lightning
Just had our 2020 Jimny serviced at the local Suzuki dealer.
Although it's 12 months old the mileage is only 3,300
The cost was £200 which seemed a little high, but looking at the invoice they've done more than just an engine oil change, they've changed the gearbox and transfer box oil as well.
Plus various other checks. lt can't be a bad thing to change the gearbox oil after the running in period, so l am very happy with the work that they have done.
They also did the 12 month bodywork anti corrosion check although l can't imagine there was much involved with that.
l will still service it myself once the warranty has run out though!
Last edit: 22 Jan 2021 17:49 by lightning.
22 Jan 2021 19:36 #232090 by Dan
Replied by Dan on topic First service after 12 months
Mine's done the same mileage as yours. I'm going to hold off until the mileage is a bit higher because I'm not convinced that there will be a degradation in the engine oil after twelve months.
As I understand from reading other posts they only change the transfer box oil once, so would prefer to have greater mileage onboard before I have that done.
I'm standing by to be flamed.
  • Chappo
22 Jan 2021 19:45 #232091 by Chappo
Replied by Chappo on topic First service after 12 months
Mines done 1500 miles, oil service lights on but it will have to wait!
No reminder from my dealer though?
22 Jan 2021 20:58 #232095 by lightning
After the Jimny is out of its warranty and l start servicing it myself l will change the gearbox and transfer box oils every couple of years.
lt's an easy and cheap job, l've got a hand pump to get the oil in, as used on my Defender.
22 Jan 2021 20:59 - 22 Jan 2021 21:04 #232096 by lightning
To answer the comment above.
How would the dealer know that your oil service light has come on? Unless it comes on after 12 months regardless of mileage, in which case l guess they could send you reminder to bring it in, if they want the work.
My understanding was that the appearance of the "service" light is your reminder.
Last edit: 22 Jan 2021 21:04 by lightning.
22 Jan 2021 23:37 #232097 by Gadget
£200 seems pretty reasonable to me. Labour is prob c.£75/hr. Couple of hours work plus fluids.
Time to create page: 0.666 seconds
