Ac compressor alternatives
- justintime441
30 Dec 2020 00:40 #231321
by justintime441
Ac compressor alternatives was created by justintime441
My ac compressor isn't working, pulled it apart and the turbine looking piece was broken. Is there any other model cars that use that compressor. I can't find any locally even used, apparently they're gold. I see on ebay some compressors out a china, has anyone had any luck with these? (I fear the poor quality)
Cheers
Cheers
- Thank you received: 2004
30 Dec 2020 05:11 #231324
Replied by Lambert on topic Ac compressor alternatives
Unless you live somewhere hot is ac actually necessary? I only use mine as an idler pulley for the belt, it stopped working properly years ago and I am no inclination to fix it. It is possible to bypass it with a shorter belt too.
- Chris38
30 Dec 2020 16:04 #231332
by Chris38
Replied by Chris38 on topic Ac compressor alternatives
Is it possible to remove all the ac gubbins, fit a shorter belt and take advantage of all the lost power?
30 Dec 2020 16:38 #231333
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic Ac compressor alternatives
Got mine from bb_autos on Ebay, no issues.
The following user(s) said Thank You: justintime441
30 Dec 2020 16:52 #231335
Yes and no. Yes you can remove it all and replace the belt with a 4pk850 same as the alternator. However assuming that the magnetic clutch on your compressor is free then you don't actually gain any power as the compressor is not constantly being powered.
Chris38 wrote: Is it possible to remove all the ac gubbins, fit a shorter belt and take advantage of all the lost power?
- justintime441
31 Dec 2020 02:11 #231360
by justintime441
Replied by justintime441 on topic Ac compressor alternatives
I live in Jamaica, temp is around 32°C all year so yeah Id like to have it. I'm actually running it using a shorter belt until I can sort out /source the compressor
Time to create page: 0.095 seconds
