Alternator again!!!?,!
29 Dec 2020 22:54 - 29 Dec 2020 23:02 #231320
by Fossie
Alternator again!!!?,! was created by Fossie
My daughters jimny has gone all French on us ....The electrics have gone on strike for no apparant reason.
Obviously this would happen when every where is closed for 2 weeks .
Anyway she has mine for the short term ......The alternator has stopped charging according to rescue chappie...which would coincide with the lights being duller and duller and going out when she braked ..
Our issue is . The alternator is only 13 months old..the water pump is new in last year...3 fan belts in 2 years ....the garage have checked the pulley and insist that is fine But there can't be anything else can there?
There has been some squealing , but not when I drove it or the mechanic .
It's going take a 'conversation' about an alternator just over 12 months old by a few weeks.:whistle:
Is it time to call time and free it from her tenure , she has just had it MOT'd and the welding done , but the brakes require Fetling, but because she is down south she is reliant on her local garage. Who are not shisters it seems.
Thoughts ?
Thoughts ?
Last edit: 29 Dec 2020 23:02 by Fossie.
- Thank you received: 2004
30 Dec 2020 05:05 #231323
Replied by Lambert on topic Alternator again!!!?,!
I would stick with it if I were you especially if it's just been tested. They cheapest car is the one you already own. Its a pity we don't have any alternative than to replace things like alternators, there was a time you'd get it repaired by a man in a shed.
30 Dec 2020 09:43 #231327
by Scimike
Replied by Scimike on topic Alternator again!!!?,!
I agree, stick with it. Re Alternator it looks like you have just got a bad one. Maybe secondhand OEM is better than cheaper made in China out of Chinesium.
You can still get it repaired here in (third world) Stoke on Trent by a nice man in a workshop, repairs starter motors also. He's fixed mine for years and a better option if you can wait a day or two for him to refurbish it.
Anyone local to you, worth a check?
Good luck
Mike
Good luck
Mike
01 Mar 2021 23:43 #233382
by Fossie
Replied by Fossie on topic Alternator again!!!?,!
So ......it's been a couple on months and all good apparently , but Robyn has lost patience/ confidence with her jimny ....mine is still still with her , so today I went to collect hers to bring home to use it here and get to the bottom of the issue ....if indeed it is still relevant.
But mine decided to stick the right rear brake on so tight even in 4wd that wheel won't even slide ....the clutch smelled though.
bugger ...so the local garage will need to have a gander. I returned sans jimny!
This evening when she used hers ...it squealed .
In conversation with a lad from the Ignis sport club this is also a problem with M13,engines because there seems to be 2 alternator belts , one is longer by just a touch say 15 mm..is this because the vvti engine and non vvti are different and when a new belt is ordered by registration number , you will always get the one the drop down box lists? Is this a possibility ?
I feel I will change the crank pulley when I can anyway , as the water pump has been done , new belts both 3x ( see possible reason above)
02 Mar 2021 06:22 #233385
The alternator belt should be a 4pk850 and whilst you could go a few mm either way there would be enough in the alternator slides to get tension. Personally I had a negative outcome with Gates belts couldn't get them to not squeal so got Dayco and everything is fine.
The following user(s) said Thank You: Fossie
- Sick Nick
02 Mar 2021 21:16 #233409
by Sick Nick
Replied by Sick Nick on topic Alternator again!!!?,!
Have you tried belt dressing spray?
Time to create page: 0.109 seconds
