Portable hoist?
16 Dec 2020 04:26 #230921 by Lambert
Portable hoist? was created by Lambert
Whatcha, as a present to me and my increasing knee and other joint injuries I am looking for a portable midrise car ramp hoist. The main use will be for removing and applying waxoyl but it will also be good for general maintenance and as Dreadnaught gets older potential welding too. I know that increasing numbers of places rent ramp time but I can see problems rocking up with the pressure washer and making a serious mess. So does anyone have any recommendations?
16 Dec 2020 10:19 #230928 by sniper
Replied by sniper on topic Portable hoist?
Have you got a tractor with a 3 point linkage and hydraulics ? If so, get an FLT mast and you can lift the car to any height, they are a useful tool on the farm too.....
I use a tele-handler at Bob's farm, it's got extended forks and a 3 ton swl so doesn't bat an eye at the Jimny. I always put a timber chock under the main arm whilst under the car.
sniper
16 Dec 2020 16:40 #230933 by Lambert
Replied by Lambert on topic Portable hoist?
The lift capacity of my main tractor is nominally the same as the weight of the car so with a carrier it would be sketchey at best.
I have seen a 1m 3000kg lift but it's not cheap, but how much do I value working comfortably?
16 Dec 2020 21:10 - 16 Dec 2020 21:12 #230939 by Scimike
Replied by Scimike on topic Portable hoist?
I have often pondered the same question, driven by the same age related issues.
Space (or lack of) is one of my main problems, you may have more availability on the farm?
For me the best fit at the moment is one of these, balancing cost etc:
ebay.us/xqo8OC
Just a quick example, seen cheaper.
If I had the space I would consider an old fashioned "brick" raised ramp, seen one at an old RAF base and just like the look.
All of the portable lifts I have seen appear to compromise access under the vehicle, but they do keep the wheels free. I personally want more under vehicle access than lifted wheels.
So not found anything better at the moment and don't have room for a tractor, although I would like one.:)
Last edit: 16 Dec 2020 21:12 by Scimike.
17 Dec 2020 04:55 #230952 by Lambert
The display ramps while cheaper aren't particularly easy to store and aren't that versatile for general service. But equally won't mind getting wet as there's no electric inside.
  • X8GGY
17 Dec 2020 05:50 #230953 by X8GGY
Replied by X8GGY on topic Portable hoist?
What about these? -
www.ebay.co.uk/i/333552586894
Time to create page: 0.112 seconds
