Underseal ,Rust prevention. Is it worth it. ?
- Roger Fairclough
- Thank you received: 225
20 Jul 2021 17:42 #236836
by Roger Fairclough
Replied by Roger Fairclough on topic Underseal ,Rust prevention. Is it worth it. ?
A lot has been learned by car manufacturers over the years concerning corrosion and how to defeat it but the basic fact is that car bodies and chassis are made of mild steel and that stuff rusts, corrodes and ultimately crumbles to dust. A major problem is where there is the chance of paintwork being damaged by a hard metal fitting that breaks through the paint and leaves raw steel open to the elements. This is where the problems start. The use of rubber grommets to fill the hole is ideal but I would add bitumastic or similar to complete the job.
Is this the only problem area and are the body to chassis mountings ok? They appear to be vulnerable to serious corrosion but only after about 10 years.
A point of interest is that Suzuki now offer a 12 year anti perforation warranty on the bodywork of Gen.4 Jimny's.
Roger
ps. I am disregarding any other materials used in body chassis construction. Suzuki use steel
Roger
20 Jul 2021 19:38 #236839
by Velocette
Replied by Velocette on topic Underseal ,Rust prevention. Is it worth it. ?
In the early 1970's I worked in a research laboratory in Harrogate where one of our projects was developing corrosion resistant steel for the motor industry and the like. We developed a system called "chromising" which was principally a powder of ground chromium and traces of other base metals which was spread of the surface of sheet steel, aided by a chemical flux then run through a rolling mill and heated to bond it to the surface. The pilot plant at Eaglescliffe was a great success and the material could make a car exhaust last over 15 years easily. Body panels correctly protected where drilled would last forever. It never went into production, we believed, because of the massive vested interests in the replacement parts industry. Shame.
- Thank you received: 1992
21 Jul 2021 05:23 #236844
Replied by Lambert on topic Underseal ,Rust prevention. Is it worth it. ?
Was that at the ICI facility on Hornbeam Park? I know they used to do some very clever things down there.
21 Jul 2021 17:29 #236853
by Velocette
It was up Harlow Hill, Albright and Wilson, in front of the Tobacco Research buildings where we used to get free fags from the lab girls there !!
22 Jul 2021 07:34 #236865
Ah yes, all office space now apart from the research place.
