NEW
- Craigyh1990
01 Dec 2020 15:13 #230555
by Craigyh1990
NEW was created by Craigyh1990
Hi there can any one tell me if the expansion tank needs filling with coolant my temps sits fine just see it has a tank there that seems to be empty as I said in a post before I’m new to Jimnys hope some one can help thanks
01 Dec 2020 15:23 #230556
by Scimike
Hi,
The expansion tank should have a fill line marked about half way up and should normally contain coolant. Fill when cold.
I assume this is the same for all Generation 3's, not sure if it ever changed over the years of manufacture.
- Craigyh1990
01 Dec 2020 15:31 #230557
by Craigyh1990
Replied by Craigyh1990 on topic NEW
Looks like a overflow bottle type thing
01 Dec 2020 16:20 #230558
by Scimike
- Craigyh1990
01 Dec 2020 16:50 #230560
by Craigyh1990
Thats the one I took rad cap off also can’t see nothing in there there from the cap hole the tempature sits just fine even with heating on or off and had a look for leaks the pipes get nice and hot coming from the radiator do I need to top both up ?
01 Dec 2020 17:14 - 01 Dec 2020 17:15 #230562
by Scimike
It should be half full of coolant when the engine is cold.
As the engine warms up the coolant within expands and is pushed past the radiator cap into this expansion bottle. As the engine cools the water contracts, this then sucks the water from the bottle back into the engine.
Its possible you are running the engine block low on coolant if its not pushing coolant into this bottle when its hot, even if the temperature gauge says all is ok.
I would top it up to half way, go for a drive then let it all cool. Check its still at half level, if not top up again. You should always have a half full bottle after every run with a cool engine (about 1 inch above half way line with hot engine). If you are continually topping this bottle up you have a leak.
Last edit: 01 Dec 2020 17:15 by Scimike.
The following user(s) said Thank You: Craigyh1990
Time to create page: 0.141 seconds
