Dash lights
- Craigyh1990
28 Nov 2020 21:22 #230479
by Craigyh1990
Dash lights was created by Craigyh1990
New to Jimnys when I put my fog lights on nothing comes on the dash same with the headlights all over lights work on dash tho so not sure am I doing something wrong
- Dirtbird
28 Nov 2020 23:14 - 28 Nov 2020 23:15 #230481
by Dirtbird
Replied by Dirtbird on topic Dash lights
I'd try FUSE BOX first then if all fuses not blown Id move to Bulbs. Had one gone in the heater control thingy?Not the end of the world but once I got it fixed .........everyone had to hear about it .
Last edit: 28 Nov 2020 23:15 by Dirtbird.
- Thank you received: 2004
29 Nov 2020 05:15 #230486
Replied by Lambert on topic Dash lights
On my gen3 the front fog lights don't have a repeat warning light and the rears are just a small light on the switch. There's nothing on the instrument cluster.
The following user(s) said Thank You: Craigyh1990
- Sergiu
29 Nov 2020 07:00 #230489
by Sergiu
Replied by Sergiu on topic Dash lights
On the Jimny, at least on the post-2005 dashboard, you only have a dash light for the high beam, everything else is missing. Interestingly on the instrument panel there is a spot for the rear fog light, it is not wired either on the car side or on the PCB side. I suspect it is a similar story for the earlier dashboard.
For the fog lights, you should have a light on the actual switch, but maybe there are multiple types of switches for the front lights, I have a confirmation light on the front fog lights switch
29 Nov 2020 19:20 #230512
by Fossie
Replied by Fossie on topic Dash lights
It's part of the charm of the jimny , it's old Skool , no warning lights that aren't needed except engine management , which like most cars will lie anyway!
If the dashboard is lit up your lights are on , because you put them on.
The fog light warning lights are on the switches and will only work with headlamps on, like the legal requirement . If you operate main beam the fog lights will / should go off and you shouldnt need both legally , so it was on early Jimnys anyway .
( The front fogs maybe won't come on although the switch and warning light say they are ...I've found this is common as all 3 of mine are so ...bulbs are fine but I'm not stripping the loom back to find where the issue is "..though could be the relay.)
- Thank you received: 679
30 Nov 2020 23:53 - 30 Nov 2020 23:54 #230539
Replied by DrRobin on topic Dash lights
I am not sure if the Jimny does it but if it is really foggy or snowing hard and you are out in the sticks (no streetlights or cars) side lights and front fog lights give me a better view at slow speed. I find the dipped headlights give too much glare.
If I am in traffic you don’t need front fog lights, I switch them off as well as rear fog lights they just blind other drivers, but switch them back on when the traffic thins.
Last edit: 30 Nov 2020 23:54 by DrRobin.
Time to create page: 0.099 seconds
