Fitting daylight running lights
- Ruedeleglise
19 Nov 2020 11:16 #230199
by Ruedeleglise
Fitting daylight running lights was created by Ruedeleglise
Any wiring diagrams and advice would be very welcome. My Jimny is a 1.3 MT SZ4
- Thank you received: 679
19 Nov 2020 11:38 #230200
Replied by DrRobin on topic Fitting daylight running lights
This is the drawing I used when installing a tow bar and reversing camera to my 2011 SZ4, but other members might have a better drawing.
forum.suzukiclubuk.co.uk/viewtopic.php?t=2097
19 Nov 2020 16:28 #230208
by Scimike
Replied by Scimike on topic Fitting daylight running lights
In simple terms you just need a simple change over relay if the DRL's are LED and low power.
Connect a fuse spur feed to 87a from a power source that is on only when the ignition.is on. The fuse box is a good source for this, i.e heater feed..
Connect 30 to your DRL +VE and -VE on the DRL to the vehicle body (earth).
Connect 86 to your a side light supply wire.
Connect 85 to the vehicle body (earth)
The result of all this is the DRL's will be on when the ignition is on, BUT they will turn off when the vehicle lights are on. This is a requirement (or dimming) of UK law.
Mike
Mike
- Ruedeleglise
19 Nov 2020 17:20 #230209
by Ruedeleglise
Replied by Ruedeleglise on topic Fitting daylight running lights
Thanks. Where would you get the relay please?
19 Nov 2020 17:36 - 19 Nov 2020 17:37 #230213
by Scimike
Hi,
On line / eBay if you can wait.
ebay.us/5Y5vwU
Halfords if you want to spend a bit more or its Sunday, look for HEF557
Or your local motor factors, but make sure it has a mounting lug.
You are also going to need some spade crimps, and a mini fuse spur, again any of the above.
You only need the fused spur if you intend to connect into the Jimny Fuse box for the DRL ignition switched supply, which is inside above accelerator pedal.
ebay.us/5Y5vwU
Last edit: 19 Nov 2020 17:37 by Scimike.
Time to create page: 0.101 seconds
