Tyre Size
- ColinTheViking
16 Nov 2020 09:01 - 16 Nov 2020 09:02 #230083
by ColinTheViking
Tyre Size was created by ColinTheViking
Right so my Jimny has been on 235's since 2007, basically from new. I decided that it would need to go down to 215's when I bought it in February as the gearing hasn't been changed to suit 235's. Soon I'm going to be getting a 2 inch lift and thought would I be able to put 235's on again? I already know without a lift it barely scraped so with the lift it should be fine. Now the gearing is where the issue's can start however it spent 13 years on 235's and never had an issue... should I even worry about putting these larger tyres on then? I hardly off-road its probably 95% road use I just like the aesthetics of larger tyres. There was hardly a difference in response and power when I went from 235's to 215's so power changes and MPG will not really make a massive difference either.
Last edit: 16 Nov 2020 09:02 by ColinTheViking.
- Thank you received: 2004
16 Nov 2020 12:04 #230089
Ultimately its your car and as long as you can live with the consequences of the bigger tyres then go for it.
- ColinTheViking
16 Nov 2020 14:56 #230103
by ColinTheViking
Replied by ColinTheViking on topic Tyre Size
What are the consequences? Is gearing change a difficult job?
- Thank you received: 706
16 Nov 2020 15:28 - 16 Nov 2020 15:33 #230104
Replied by jackonlyjack on topic Tyre Size
It's the cost gearing changes aren't cheap
I already have 4:16 transfer
Now thinking of a bigger lift and 215 85 16's
Last edit: 16 Nov 2020 15:33 by jackonlyjack.
Time to create page: 0.099 seconds
