rust protection
  • cjhtom123
27 Oct 2020 20:50 #229501 by cjhtom123
rust protection was created by cjhtom123
Hi
I have a 2014 Jimney (40,000 Miles) which, I have recently spent some time undercoating in the hope of delaying the rust bug!
Overall, underside was I thought in in reasonable condition given age, and any surface rust visible mostly at at usual seam locations was cleaned and treated. That said, I did feel the protection on the underside looked fragile given our winters and what I have had on other cars.
Some questions please:
Are later cars better rust protected underneath, or they all have the same basic level of protection?
Where are the main areas to watch out for and at what point in a cars age does rusting become a major issue?
Understand the cars usage has a bearing on replies, but assuming general, no off road usage.
Many thanks in anticipation.
Regards all
27 Oct 2020 21:32 - 27 Oct 2020 21:42 #229502 by Scimike
Replied by Scimike on topic rust protection
Hi,
You have done the correct thing in tackling any corrosion before it gets hold.
No later cars are not protected any better, they have just seen less use.
The body locations are first to go as the metal is thinner, the chassis generally takes a lot longer before it's an issue. I would suggest about 10 years to perforation of the body at some point if you do nothing.
A suggested order of rot table:
1) Front body mount under the headlamps is my prime rust spot. Hidden by the arch liners, these can be a rust hole in less than 10 years if not treated.
2) Jack storage area floor, the bit above the rear silencer.
3) Rear body mounts
4) Sills and body mounts just behind front wheels
5) Everything else! - rear tub floor to inner wing / door bottoms and behind any plastic trim etc
Cavity wax in these areas injected into any box sections is the way to go.
How long till it's an issue? That's very hard to say. Suzuki's random protection techniques and previous owner use / maintenance mean that for every bad one you find a good one, so it's no guarantee my list will apply to all Jimnys.
However generally do nothing and at 10 - 15 years your MOT may start to include the odd welded repair. Once you start welding it generally does not get any better!
Relax though, just get your preferred wax or sheep based protection under the vehicle and keep it topped up every 2 years. Should keep the rot away.
Mike
Last edit: 27 Oct 2020 21:42 by Scimike.
  • cjhtom123
28 Oct 2020 00:12 #229503 by cjhtom123
Replied by cjhtom123 on topic rust protection
Mike,
Many thanks for full and comprehensive reply.
Not much to add after that...
Thanks again,
Tom
28 Oct 2020 05:37 #229504 by Lambert
Replied by Lambert on topic rust protection
Echoing what Mike said, I started with the waxoyl fresh off the forecourt when mine was new and now nearly 10 years later Dreadnaught is in about the same condition as my Spare Jimny when we bought her untreated at 3 years old. You can't prevent corrosion but you can slow it down.
Time to create page: 0.098 seconds
