Buying advice
- Id59
04 Oct 2020 15:41 #228772
by Id59
Buying advice was created by Id59
Help wanted please, I am in Czech Republic and looking at buying Jimmy for our snowy season and use in our woods . I have seen a 2011 hardtop in good condition visually with service history etc at price I am happy with. Having had a discovery before with enormous electrical problems , I am wary of the push button electric/vacuum 4wd hubs , I started the car in 2wd no light on dash , what should I see when I push 4wd and 4lo . Also what should I look at in nparticular before doing the deal
Thanks in advance
Ian
Thanks in advance
Ian
- Thank you received: 2004
04 Oct 2020 15:51 #228773
Replied by Lambert on topic Buying advice
Welcome to the forum. There a buying guide in the information section on the top banner. That said the 4x4 light will flash and then remain steady green. The low light will again flash as it engages and then remain steady. Otherwise on a 2011 the car really should be clean and tidy and rot free though some surface rust can be expected on suspension components if it hasn't been treated with a wax or similar preservatives.
The following user(s) said Thank You: Scimike, Id59
04 Oct 2020 16:58 - 04 Oct 2020 16:59 #228776
by Scimike
Replied by Scimike on topic Buying advice
Just to expand a little on Lambert's answer.
When you shift 2H to 4H keep the front wheels in straight ahead position and speed under 100kph. Or do it stationary.
The 4x4 low engagement (4H to 4L) needs a few prerequisites before it will engage. The vehicle must be stationary. It needs the clutch Pedal pressed down fully if a manual, or in N if automatic before it will engage.
Last edit: 04 Oct 2020 16:59 by Scimike.
The following user(s) said Thank You: Lambert, Id59
Time to create page: 0.086 seconds
