Re:Re:Re:Eibach 25mm pro lift springs
  • McVicar
22 Jan 2021 17:17 #232082 by McVicar
Replied by McVicar on topic Re:Re:Eibach 25mm pro lift springs
Lambert, if you were doing it again what would you recommend to just make for a more comfortable ride on tarmac only.
22 Jan 2021 18:52 #232088 by Lambert
Either trailmaster comfort or avo adjustable set to softer. Spring wise probably same again suplex front and Monroe rear in standard height.
  • McVicar
22 Jan 2021 20:35 #232094 by McVicar
Replied by McVicar on topic Re:Re:Re:Eibach 25mm pro lift springs
Thank you
  • Jamin
23 Jan 2021 00:56 #232100 by Jamin
Replied by Jamin on topic Re:Re:Re:Eibach 25mm pro lift springs
If you read the thread you'll find your answer.
  • McVicar
23 Jan 2021 07:49 #232101 by McVicar
Yeah, thanks for that.
  • McVicar
04 Feb 2021 14:03 #232466 by McVicar
Replied by McVicar on topic Re:Re:Re:Re:Eibach 25mm pro lift springs
The question of tyre pressures got me thinking. I reduced my tyre pressures from 23/26 to 22/24 and am amazed at how much softer the ride is. I know the implications re handling, fuel economy and tyre wear but I can live with that.
Time to create page: 0.219 seconds
