Squealing
- Thank you received: 679
15 Sep 2020 12:33 #228232
Hi,
Yes, check them both first and see which one is slack then adjust. The alternator belt is tensioned by swinging the alternator outwards (to the left), slacken both bolts on the arm at the top and it pivots on a bolt at the bottom. Mine was very tight on the pivot bolt and had to use a mallet and block of wood to move it.
The PAS belt is tensioned by moving the tensioner pulley, it is held in with two bolts, one in the centre which holds the pulley and one off to one side which locks the tensioner in the correct position. Both bolts are 12mm and difficult to get to with the fan in place, but to remove the fan, you have to remove the radiator and I wouldn't recommend that. A 1/4" socket works well, but both of my bolts were tight and had to use a 1/2" drive to free them off, it just went in.
- ColinTheViking
15 Sep 2020 12:38 #228233
by ColinTheViking
Replied by ColinTheViking on topic Squealing
Is there a torque level for re tightening the bolts?
15 Sep 2020 15:55 #228234
There are some torque settings in the BigJimny wiki and may be some more here
www.suzukiclubuk.co.uk/tech-specs/torque-settings
I didn't find a torque setting for the tensoiner bolts, mine were pretty tight so I put them back in slightly less tight. I didn't measure it with a torque wrench, I have the following rough guide.
Normal - will come out with a spanner (yeah right, not many of those then)
Slightly tight - will need a socket
Tight - will need a good pull on the socket (or several good pulls)
Very tight - will need a breaker bar (or perhaps a mallet)
Over tight - will need the breaker bar plus a good pull or extension (lump hammer)
Far too tight - will need the blow lamp, easing oil, long extension, lot of swearing, large lump hammer and a lot of time.
Most things I seem to have to take off for the first time are in the last three categories.
My pulley wheel was over-tight, the alternator was also very-tight to over-tight, the tensioner bolts were tight to very tight. I used a torque wrench on the pulley, but just put the tensoiner bolts in to tight.
The spare wheel for example was in the far too tight, I actually consider drilling it off or cutting the bracket. Not helped by the fact that the previous owner had put it on with a locking kit and not supplied the key. Since the wheels had no lock kit on them I assume he was unable to remove it before selling the vehicle.
Time to create page: 0.081 seconds
