Chassis Plugs
07 Sep 2020 23:42 #227908 by Johnniehec
Replied by Johnniehec on topic Chassis Plugs
Quick squirt through with the power washer
  • Nothsa
06 Dec 2021 08:55 #240502 by Nothsa
Replied by Nothsa on topic Chassis Plugs
I think those plugs are waste of money, it keeps the water and all other stuff in as good as holds them out… worse part is that they prevent evaporation so I’d say no don’t do it
06 Dec 2021 09:46 #240503 by Roger Fairclough
Replied by Roger Fairclough on topic Chassis Plugs
Just pushing them into place is not a good idea because they will leak. The seal lips "may" be OK but the tubes will not be smooth. If you do wish to try it you must use an RTV sealant and then remove the plugs at 12 month intervals to check the tubes condition.
On my LC I cleaned out the tubes and applied a coat of bitumastic paint using a long bristle brush. After 25 years tubes were still OK, whereas Jimny chassis tubes do appear to rot out.
My advice, forget the plugs, paint with the bitumastic and keep an eye on them.
Roger
06 Dec 2021 10:54 #240504 by lookonimages
Replied by lookonimages on topic Re:Chassis Plugs
Roger Fairclough wrote: Just pushing them into place is not a good idea because they will leak. The seal lips "may" be OK but the tubes will not be smooth. If you do wish to try it you must use an RTV sealant and then remove the plugs at 12 month intervals to check the tubes condition.
Roger
agree
06 Dec 2021 15:43 #240514 by 300bhpton
Replied by 300bhpton on topic Chassis Plugs
What are peoples thoughts on THESE ?
I have some reservations myself, even if the tube is well coated inside with wax first, I would still be worried about trapping moisture and build up of condensation.
Anyone used them long term?
Avoid would be my vote.
I had a look on Ebay the other day at what items were being offered as I hadn't looked for a while. My word 95% of them seemed to be utter useless tat!
06 Dec 2021 19:47 #240521 by fordem
Replied by fordem on topic Chassis Plugs
I'm going to buck the trend - I've seen enough rotted chassis tubes to know that left open they fill with wet mud that starts the corrosion - I have mine plugged.
Time to create page: 0.207 seconds
