Re:Horn upgrade
- Roger Fairclough
- Thank you received: 225
17 Aug 2020 09:39 #226829
by Roger Fairclough
Replied by Roger Fairclough on topic Horn upgrade
I fitted a Fiamm air horn with twin trumpets. The term "Audible warning of approach" should be just that, Audible.
Roger
Roger
- Grim Reaper
- Senior Member
- Thank you received: 10
17 Aug 2020 10:56 #226838
by Grim Reaper
Replied by Grim Reaper on topic Horn upgrade
£7.93 10%OFF | 115dB Loud Horn Auto Speaker Alarm 12V Tone Vehicle Boat Car Motor Motorcycle Van Truck Siren Car Horn signal for auto siren
a.aliexpress.com/_BSOgDQ
17 Aug 2020 20:20 #226866
by treps
Replied by treps on topic Horn upgrade
Looks good. Is it just a matter of replacing the existing horn with this one, using the same wiring, or is it more complicated? Many thanks.
- Grim Reaper
- Senior Member
18 Aug 2020 13:23 #226906
by Grim Reaper
It needs a permanent 12v supply otherwise the tone reverts to the first one, I used a spare live appearance in the fuse box that I attached a small spade connector to.
I mounted mine under the front, behind the arb off a spare captive nut down on the chassis
- Podge
09 Sep 2020 11:46 #227984
by Podge
Replied by Podge on topic Horn upgrade
I used a pair of Hella Sharptones mounted up front with a little fiddling, I'll take a photo later.
I put a fused 12v+ and a 2nd relay to trigger them, I took a feed off the existing relay so when the horn is pushed, it trips the OEM relay which then supplies 12v to the main relay for the new horn.
They're obnoxiously loud, just what you want in a small car like the Jimny, they cut through anything.
09 Sep 2020 21:04 #228015
by crash486
Replied by crash486 on topic Re:Horn upgrade
An Aussie has fitted a train horn to his. Mounted on the roof rack. I'll see if I can find the video.
I've experienced it in person. It's not something that can be ignored.
crash486 JB74W
crash486 JB74W
The following user(s) said Thank You: lightning
Time to create page: 0.199 seconds
