Oil level question?
  • Jimny2003
09 Aug 2020 19:14 #226417 by Jimny2003
Oil level question? was created by Jimny2003
Hi all,
Just drained and filled my gearbox and transfer box...added the stated capacities of lovely fresh oil, but it didn't run out of the filler hole....??? so I am assuming...stick to the stated capacities and the filler plug/hole is not the "full" point, so won't necessarily run out after the correct capacity has been added? Cheers
09 Aug 2020 19:26 #226419 by lightning
Replied by lightning on topic Oil level question?
Normally a gearbox or transfer box is filled until oil runs out of the filler hole.
But if you've added the correct quantity of oil, maybe the Jimny is different.
lf that's the case, it would certainly make refilling the gearbox less messy.
The following user(s) said Thank You: Jimny2003
09 Aug 2020 19:33 #226421 by Lambert
Replied by Lambert on topic Oil level question?
I have always filled to the level plugs on flat ground, reasoning that they put the fill point where it is because that is the correct capacity and I'd rather trust that than the questionable accuracy of my ability to measure a specific amount of oil laid on my back on my drive.
  • CC Baxter
09 Aug 2020 19:40 #226423 by CC Baxter
Replied by CC Baxter on topic Oil level question?
Always fill to the level plug, that's standard workshop practice. Chris
  • Mr CC
09 Aug 2020 23:59 #226436 by Mr CC
Replied by Mr CC on topic Oil level question?
would like to ask, which oil do you use for each box
I definitely need to change mine, but a little lost when it comes to gear oil
10 Aug 2020 03:55 #226437 by Lambert
If you look in the Jimny information section above there is a wiki with all that info.
Time to create page: 0.095 seconds
