Re:Tonka's poorly
- Roger Fairclough
Topic Author
- Thank you received: 225
09 Aug 2020 08:43 #226378
by Roger Fairclough
Tonka's poorly was created by Roger Fairclough
Went out for the day last Friday and reached Worcester (15 Miles) when motor cut out. Backed off throttle and motor resumed. Struggled through one lane system on roadworks when she resumed after dipping clutch and pumping throttle. Continued on but motor obviously struggling so turned back.Reached Redditch with serious loss of power. could be coaxed up to 50 mph but only slowly. Drop to 40 and full throttle and she died; back off and she picked up. Booked into dealer next wednesday.
All suggestions gratefully received.
Roger
ps. Tonka is a gen.4 with 1800 miles.
Roger
- Thank you received: 679
09 Aug 2020 09:12 #226380
Replied by DrRobin on topic Tonka's poorly
Sounds like either blocked fuel line or blocked air filter. Unless something has gone wrong with the ECU or a sensor.
- Thank you received: 2004
09 Aug 2020 09:30 #226383
Replied by Lambert on topic Tonka's poorly
The gen4 is a bit new for any common faults to have manifested in sufficient numbers for easy diagnosis. That said I would also suggest a sensor fault or if you are lucky a loose connection. Do you have the fuel filter guard, something could have flicked up off the road and damaged a wire or line?
09 Aug 2020 09:46 #226385
by Scimike
Replied by Scimike on topic Tonka's poorly
Sorry to hear about your problem, the dealer is the answer if it's in warranty, it's also feeds any issues into Suzuki's system on new vehicles.
This modern stuffs a pain if the diagnostic software is poorly written, the ECU has carte blanche to do what it wants with the engine and it's not always clear why. The G3 typically never puts up error codes for failed or fault sensors, I guess it's just not in the software to do so.
My last car (VWpolo) had the problem your are describing, turned out the cooling fan was not plugged in (new car!). No Temperature gauge on this modern stuff, only over temp warning light. ECU detected hot temperature and backed off engine performance accordingly, even to the point that the car would not rev ( side of roadworks ). Never turned on the over temp warning light as ECU prevented this, no error codes. Net result is I had a car for two years with a random power loss fault. Poorly written diagnostic software, only found the issue by chance..
So much for advanced diagnostic ECU control, what was wrong with a temperature gauge?
Mike
Mike
- GeorgeC
09 Aug 2020 09:50 - 09 Aug 2020 09:52 #226386
by GeorgeC
Replied by GeorgeC on topic Tonka's poorly
Roger you are not the first.
My experience was merging into a motorway @ 100kph,
I think the thermo-fan cut in, then the motor cut out.
No response to depressing the throttle, so I backed off looking for somewhere to run-off the motorway, but the motor came back, I regained the speed of 80kph only!
I monitor voltages, merging 12.1V, at cut-out 11.8V and dropping, after the resumption of power 12.2V.
My Initial Diagnosis was loose wire or bad connection in the Alternator/Regulator/ECU, I move harness, the problem changes.
I suggest monitoring voltages if you have electrical anomalies.
There are anecdotal reports of the motor shutting down at 11.5V!
My car then spent 15 days in the workshop, no fault was found!
Last edit: 09 Aug 2020 09:52 by GeorgeC.
- Roger Fairclough
Topic Author
09 Aug 2020 14:07 #226394
by Roger Fairclough
Replied by Roger Fairclough on topic Tonka's poorly
Update.
Doc. Robins comment made me think of a situation from many years ago when a fuel filler cap stopped venting and tried to create a vacuum in the tank. This situation has caused tanks to implode so I checked the cap on Tanka and all appeared ok. I then drove her for about 10 miles using 5,000 rpm where possible and up to 80 mph.
Not a flutter, not a cough, not even a stutter. Back to base, jump out and unscrew fuel cap. No hissing.
Point to note. On startup from cold engine cooling fan came on within a few seconds and that it should not do.
Roger
Roger
Time to create page: 0.110 seconds
