Car dolly
- mickt
08 Aug 2020 12:26 #226347
by mickt
Car dolly was created by mickt
At the moment I have my soft top car stripped of eng and gearbox and back axle and transfer box and its on axle stands. I have a bit of welding to do and want to make a wheeled dolly to be able to move the car about to give me the room to get under it better. Now the chassis is a pain as it is at different heights front to rear and the centre part between the front rear spring mounts and the rear front spring mounts is not straight and although its possible to make a frame to fit it I wonder if the balance of the car will be correct in the front to rear axis.Hhas anybody made or seen a dolly to fit the bill or got any ideas to make one?
- Thank you received: 2004
08 Aug 2020 12:33 #226349
if you're making one anyway why not, if you haven't already, remove both bumpers and pick up the ends of the chassis kinda like a rotisserie but fixed and on wheels?
- mickt
09 Aug 2020 19:26 #226420
by mickt
Replied by mickt on topic Car dolly
I have not but it is a great idea as it would allow total access with the whole caboodle underneath. Most of the rust is at the rear wheel arches and rear member. Thanks for reply. I will start on it in the near future after I finish a couple of other projects like my welding table mods.
- CC Baxter
09 Aug 2020 19:34 #226422
by CC Baxter
Replied by CC Baxter on topic Car dolly
A neighbour made a rotisserie dolly for his Triumph Spitfire and itbworked a treat too. Inevitably the dolly was chopped up nfor another project when it had served its purpose. Chris
- mickt
10 Aug 2020 18:55 #226475
by mickt
- mickt
15 Aug 2020 10:53 #226708
by mickt
Re-inspecting the rear the upper part of the chassis is a open ended rectangular box section so I think I can utilise that as the dolly mounting points.
Time to create page: 0.103 seconds
