Re:Bit of help needed here
- Max Headroom
Topic Author
- Banned
- Thank you received: 217
07 Aug 2020 20:13 - 07 Aug 2020 20:15 #226266
by Max Headroom
Replied by Max Headroom on topic Re:Bit of help needed here
Thanks Kirkynut.
Well it's turned out to be not good news
I caught up with an old RAF colleague of mine who was always a bit of an ace with electrics and he went over a whole load of tests.
His code reader found "random multiple misfire detected" and on further investigation found the front O2 sensor reading a high voltage indicating a rich mixture.
He routinely went through the plugs coil packs and HT leads and found them all acceptable, so went on with a compression test which gave the following results:
#1 Cyl 9.75 Bar (141.4118 psi)
#2 Cyl 8 Bar (116.03 psi)
#3 Cyl 9 Bar (130.534)
#4 Cyl 9.75 Bar (141.4118 psi)
So he thinks there is a good chance that there are burnt out exhaust valves on 2 & 3
Last edit: 07 Aug 2020 20:15 by Max Headroom.
- Thank you received: 1997
07 Aug 2020 20:33 #226273
Replied by Lambert on topic Re:Bit of help needed here
Oh no! Cylinder 2 certainly doesn't sound happy. Time for a 1.6?
- Max Headroom
Topic Author
- Banned
07 Aug 2020 20:46 #226275
by Max Headroom
Alas, it will be as much as I can afford to fix this, nevermind a 1.6 conversion
Time to create page: 0.169 seconds
