Re:Bit of help needed here
- Max Headroom
Topic Author
- Banned
- Thank you received: 217
04 Aug 2020 23:05 - 04 Aug 2020 23:08 #226093
by Max Headroom
Replied by Max Headroom on topic Re:Bit of help needed here
Update:
I'm still no further forward with this annoying problem.
The journey to Shropshire at the weekend seemed ok but the journey back bacame steadily worse the further I travelled, particularly after ascending a steep 1.5 mile hill (Fish Hill at Broadway). Curiously I had made the same ascent of this local hill during the previous day with no problems.
The difference between this journey and the previous day was that the car had now been running for a lot longer (from Shropshire) and I was using heater fan and lights as it was getting dark - this was the exact same situation a month or so earlier when I nearly didnt get home at all.
Anyway, after the hill, the engine coughed and spluttered more and more. I briefly pulled over and tried recycling the ignition but it made no difference
I also tried slamming my foot hard down on the throttle - the engine would stutter badly before accelerating through the rev range.
I did get home but the car wasn't happy at all.
No warning lights and no codes.
Talking with a colleague at work the next day, he seemed to think there should be some kind of amplifier for controlling the coil-packs and thought it would be that - but I have never heard of these being mentioned in any fault-finding discussions on here.
I'm still in the dark with this problem
Last edit: 04 Aug 2020 23:08 by Max Headroom.
- Thank you received: 1999
05 Aug 2020 05:25 #226094
Replied by Lambert on topic Re:Bit of help needed here
When you changed your plugs and coils did you do the leads too, also who supplied them? I changed my leads to some from euros a few years ago and they only lasted about 3 months before giving similar ish problems.
- Max Headroom
Topic Author
- Banned
05 Aug 2020 10:43 - 05 Aug 2020 10:44 #226096
by Max Headroom
Hi Lambert - no - the leads weren't changed; just plugs and coils.
The plugs aren't the expensive iridium ones, but are correct NGK.
I can't recall the brand of coils but they're from a very reputable local motor-factors supplying local garages around here
I should add I didnt do the work myself - this was done by a good local workshop well versed with vehicles of this typle and agricultural machines
Last edit: 05 Aug 2020 10:44 by Max Headroom.
05 Aug 2020 12:33 #226100
I see a set of good quality plug leads in your immediate future.
- Max Headroom
Topic Author
- Banned
05 Aug 2020 18:01 #226109
by Max Headroom
Yes I think I do too
07 Aug 2020 07:19 #226194
by kirkynut
Replied by kirkynut on topic Re:Bit of help needed here
Reading through this I agree with Lambert on the working through it methodically and the basic old fashioned component checks first.
The load on the engine bit could indicate the plug leads as the engine will be throwing in a lot of fuel with you at wide open throttle but the engine is labouring. It will need a nice fat spark to ignite all of that fuel properly and if it can't it will get wet plugs and run rough.
Jimny's can be susceptible to issues like this. If you start it and stop it straight away on a cold start, then start it again it may run rough. They do that. If you leave it 2 minutes or so it will be fine.
So I wonder, if you get it running rough when hot again, leave it off longer to see if it runs ok after 2 minutes, rather than just off and on again.
Pop new leads on anyway.
Time to create page: 0.200 seconds
