Modified V Standard drive quality
19 Jul 2020 19:00 #225338 by kirkynut
Today I drove a standard 2003 Jimny. Something I've not done in years as mine has been lifted since I bought it over a decade ago and has since gained a rocklobster transfer box, external cage, metal bumpers and a winch.
My suspension consists of BigJimny Store 3" springs, Rough Country shocks and Off Road Armoury later spec castor correction arms.
The standard Jimny I drove today has 86k miles on it but none of the shocks leak and they all visually look ok.
I have to say that I prefer the ride quality of my lifted Jimny with no anti-roll bar.
My shocks and springs soak up bumps much better than the standard set up, possibly helped by the extra volume of air in the bigger tyres (237/75/15).
I was also underwhelmed by the acceleration. I thought it would be much more sprightly than my heavy caged and winch laden Jimjam but actually, it was only slightly brisker.
I have a slight whine from my old rocklobster with welded gears rather than new, but it's really not that much noisier in real terms. The high revving engine that needs to be worked creates quite a bit of noise in the standard car, more than I remember from when I owned one.
It's funny what you forget over the years when you have romantic idealisations over a model of car. I genuinely remembered standard Jimny's being a bit quicker and a bit more refined than they actually are. I thought I'd lost so much refinement from mine but I haven't, it jusr never existed.
I still love Jimnys though. I just accept them for what they are.
19 Jul 2020 19:53 #225348 by Lambert
One of these days you will have to have a go in my little Dreadnaught. If you are lucky I might even get the track springs under her and you can experience the joy of zero body roll (and a compacted spine injury).
19 Jul 2020 20:04 #225351 by kirkynut
Lambert wrote: One of these days you will have to have a go in my little Dreadnaught. If you are lucky I might even get the track springs under her and you can experience the joy of zero body roll (and a compacted spine injury).
Now Dreadnaught might be slightly sprightlier as it has VVT!
I think I secretly hanker after a 1.6!
19 Jul 2020 20:10 #225354 by Lambert
She is no drag racer not by any means but when we find a twist or 20 then we have fun with science aka conservation of momentum aka keep your foot in it you'll be fine!
21 Jul 2020 07:40 #225414 by kirkynut
Lambert wrote: She is no drag racer not by any means but when we find a twist or 20 then we have fun with science aka conservation of momentum aka keep your foot in it you'll be fine!
Oh yes Lambert! I have a great deal of experience in driving slow cars fast!
21 Jul 2020 09:21 #225425 by Busta
From my experience having driven a handful of standard Jimnys the way they drive varies a lot even without taking modifications into account. Fresh shocks, good tyres and the correct tyre pressures can make night and day difference to a standard car. Even the condition of the seats makes a big difference! And I'm sure there is even greater range once you start considering modifications. Sounds like yours is done well though. For example, not many people bother to change the gearing but clearly that is a big factor in performance once you play with tyre sizes. I changed my diffs to compensate for 215/75r15 tyres and it's made a positive difference.
I do agree that they drive smoother without the anti roll bar, albeit with a bit more body roll.
