Re:Jimny gearsbox problem
  • equinox69uk
11 Jul 2020 13:13 #224833 by equinox69uk
Jimny gearsbox problem was created by equinox69uk
Hi everyone, new on here but would really appreciate some help, not an expert on jimnys but own 2, I need help with one, its a 55 plate with a vvt engine and electric transfer box, the problem is the gearbox has gone big time and i need to source a new one which i am finding very hard to do, also could anyone help with which box i would need, i have been told its an R72 box but not sure, also where could i go to try and find one , thanks in advance
11 Jul 2020 17:09 #224836 by Lambert
Replied by Lambert on topic Jimny gearsbox problem
Welcome to the forum. The boxes are rebuildable. A specialist will charge around 500 to 900 pounds depending on where you are in the UK. The r72 that you have is notorious for having open bearings that don't have sufficient lubrication. Suzuki amended the design to a sealed type in 2009 and these are used in a rebuild.
12 Jul 2020 04:03 #224853 by Old Neil
Replied by Old Neil on topic Re:Jimny gearsbox problem
Lambert wrote: Welcome to the forum. The boxes are rebuildable. A specialist will charge around 500 to 900 pounds depending on where you are in the UK. The r72 that you have is notorious for having open bearings that don't have sufficient lubrication. Suzuki amended the design to a sealed type in 2009 and these are used in a rebuild.
Sorry Lambert for hijacking this post
When rebuilding gearbox it's best leave seals on the bearings due to lack of oil circulation in gearbox, your experience has saved me a world of grief
12 Jul 2020 05:42 #224855 by HUN
Replied by HUN on topic Re:Jimny gearsbox problem
Just to give an idea of what parts your R72 gearbox needs (in case of a full reconditioning)
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
12 Jul 2020 05:55 #224856 by HUN
Perhaps there will be a reconditioned gearbox for sale in the near future? :whistle:
bigjimny.com/index.php/forum/18-build-th...ad-lightly?start=192
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
12 Jul 2020 06:05 #224858 by Lambert
Replied by Lambert on topic Re:Jimny gearsbox problem
Yes in the r72 box but in the earlier pre 2005 r7me box the oil circuit was better and those older boxes were very very reliable.
The following user(s) said Thank You: Old Neil
Time to create page: 0.115 seconds
