Getting ripped off?
- ColinTheViking
06 Jul 2020 11:19 #224581
by ColinTheViking
Getting ripped off? was created by ColinTheViking
So on Saturday I broke down on the road. RAC came and towed me to a a garage as they couldn’t fix the issue, it’s a broken crank shaft pulley. I would replace it all myself as it seems kind of simple to do but I’m at the mercy of the garage because I have no way of towing the old boy home. Now I just want to double check that I’m not being ripped off. They’ve quoted £350 for new belts and pulley all original Suzuki parts. I feel like that’s on the high side but I’m not sure? Any ideas?
- Thank you received: 706
06 Jul 2020 14:45 #224591
Replied by jackonlyjack on topic Getting ripped off?
How far from home is the garage?
Maybe get a quote from an independent recovery service.
Price up parts. Then recovery to your home price
Then see if a significant savings could be had
06 Jul 2020 15:39 #224597
by Scimike
Replied by Scimike on topic Getting ripped off?
Cant argue with the logic above ^^^
Just to add I believe that removing the front crank pulley may require draining the cooling system and removal of the radiator(s), as sometimes the nut can be tight and access is poor. Or its just easier if the rads not in the way. Just for consideration if you feel like the DIY approach.
06 Jul 2020 21:48 #224611
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Replied by HUN on topic Getting ripped off?
Genuine Suzuki parts are expensive. Genuine crank shaft pulley costs £187, aftermarket £71!
BigJimny shop is a good place to their check prices.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
- ColinTheViking
06 Jul 2020 21:57 #224613
by ColinTheViking
Replied by ColinTheViking on topic Getting ripped off?
I ended up having to go with their price since it’s my daily and I don’t have time to wait for parts and then take radiator off etc to swap it out. I guess on the positive they use genuine Suzuki parts but still a bummer having to cough up £350 when trying to save for 2” lift.
08 Jul 2020 08:18 #224673
by Busta
Replied by Busta on topic Getting ripped off?
A 2" lift isn't much good on a car that doesn't run. Always best to get the basics right before you start spending on modifications!
Time to create page: 0.103 seconds
