Mystery problem
- partho00
19 Jun 2020 18:56 #223748
by partho00
Mystery problem was created by partho00
Hi all,
So.. I get a call from the wife in the afternoon saying that Sulu her 05 Jimmy Auto has broken down and she’s stuck. Engine stuttering, almost no power and stalling engine. She managed to crawl it to her destination and I agree to drive down after work and have a look.
So a few hours later I drive down, start it up, runs perfectly, drive around for 10min, no problems. She had just filled up and not driven much during the lockdown so I assumed some sediment or rust in the fuel causing the problem which had just been pulled through or settled.
We start the 40min drive home and about 25min in the hazards come on, she pulls over. Again engine stuttering. Stalls, wait 2min, turn back on and running fine again. So set off again.
10min later, just 5miles from home, hazards back on again, pull over. Again engine stuttering and shaking and eventually stalls.
This time we restart and same stuttering shaking again. This just keeps happening and Sulu just won’t idle properly.
I tried disconnecting the mfs, no change. Wiggle the leads, nothing disconnected or split that I can see. Disconnect battery and re-connect same stutter. Just about to call out breakdown cover, try one last time and she starts and idles perfectly.
Start our drive home and same again, loss of power stuttering. This time we push through the 5 miles, try and keep the revs up and make it back home before stalling.
I know it’s no much info to go on, but intermittent problems like these always end up being a pain. I’m no mechanic but a keen tinkerer. Anyone got any thoughts or is it straight down the local garage.
Thanks in advance,
Tom
Thanks in advance,
Tom
19 Jun 2020 19:40 #223750
Replied by mlines on topic Re:Mystery problem
Cam or crank sensor failing by the sound of it
The following user(s) said Thank You: partho00
19 Jun 2020 20:21 #223751
by gv42
Replied by gv42 on topic Mystery problem
THE same as my jimny it was the crank sensor failing
- Max Headroom
- Banned
- Thank you received: 217
22 Jun 2020 23:28 - 22 Jun 2020 23:29 #223883
by Max Headroom
Replied by Max Headroom on topic Mystery problem
Exactly that happened to me - damn the expense and trying to identify which sensor was the culprit - I changed both of the blighters in the end.
Martin accurately helped out with the correct part number identification as my Jim is a bit of an anomaly, apparently. (Thanks again Martin)
It runs as smooth as silk now
Last edit: 22 Jun 2020 23:29 by Max Headroom.
- partho00
28 Jun 2020 17:34 #224170
by partho00
Replied by partho00 on topic Mystery problem
Update: changed crank sensor but no joy. Next job is cam sensor. Fingers crossed!
- Max Headroom
- Banned
28 Jun 2020 21:13 #224199
by Max Headroom
Good luck! Lets hope the next one is a cure
Time to create page: 0.154 seconds
