Suspension uplift
  • New boy
12 Jun 2020 15:14 #223533 by New boy
Suspension uplift was created by New boy
Can anyone recommend a garage in Cleveland that could supply and install a new suspension set up to increase my 2019 Jimny’s ground clearance by 50mm.
12 Jun 2020 20:40 #223538 by Lambert
Replied by Lambert on topic Suspension uplift
Welcome to the forum. I'm a bit too far south to reccomend anyone. It is however not a particularly difficult job if you have some basic tools and a bit of ability or alternatively it is not going to be a big job for a garage. Do you already have or know what kit you are wanting to use? Also don't forget that a suspension lift doesn't increase the clearance under your differentials it just lifts the chassis relative to the axles which allows you to fit bigger tyres.
  • New boy
12 Jun 2020 20:55 #223539 by New boy
Replied by New boy on topic Suspension uplift
Thanks Lambert,
I think you just pointed out the obvious, which I had not thought of ( inexperience), I’m using the car a lot for working well off road and while it’s been brilliant in the good weather up to press I wanted to make the car as ready for the winter as possible. To date I have just had all terrain tyres fitted,
Any advice would be welcome as I am new to this.
13 Jun 2020 08:01 #223541 by j999pre
Replied by j999pre on topic Suspension uplift
Hi. I sell lift kits but don't install.
Message me if you want a price.
James
Grey pick up Jimny
13 Jun 2020 08:34 #223542 by mlines
Replied by mlines on topic Suspension uplift
Trailmaster Comfort Lift kit is for sale in the BigJimny Shop
www.bigjimny.com/store/trailmaster-50mm-2-lift-kit-2019.html
There are some pictures and a video in the store advert.
You would have to find a small garage locally to fit, it is straight forward for them.
13 Jun 2020 09:47 - 13 Jun 2020 09:49 #223545 by Scimike
Replied by Scimike on topic Suspension uplift
Hello and welcome along.
No doubt that a lift, coupled with larger tyres, is going to improve the vehicle ground clearance and potentially get you over larger obstructions (no guarantee in this game :laugh: )
But you have said your Jimny has coped with the terrain so far and your main concern is winter. Winter will present wetter ground or frozen / snow covered ground, so your main issue will be traction unless you plan to hit more uneven ground.
So could your money be better spent on snow specific tyres, ARB locker or winch?
A winch has the advantage that when you do get stuck, being alone, your could potentially recover the vehicle.
Just putting it out there for discussion as this appears to be requirement for a working vehicle and not a full blown off road warrior.
What would you spend your money on if you could only change one thing?
Me - I woul fit an ARB or LSD diff.
Last edit: 13 Jun 2020 09:49 by Scimike.
