Wheel Spacers
- Silver05
09 Jun 2020 19:37 #223417
by Silver05
Wheel Spacers was created by Silver05
hi gang
new member, just bought an 05 for a bit of fun at the weekends, after some wheel spacers... anything recommended or got any for sale ?
cheers
David.
cheers
David.
09 Jun 2020 20:54 #223419
by gv42
Replied by gv42 on topic Wheel Spacers
A JIMNY WELCOME FROM N/WALES
- Thank you received: 2004
10 Jun 2020 05:26 #223424
Replied by Lambert on topic Wheel Spacers
Welcome to the forum. Best recommendation would be not to bother with wheel spacers unless you like changing your wheel and kingpin bearings on a fairly regular basis.
10 Jun 2020 07:04 #223425
by kirkynut
Replied by kirkynut on topic Wheel Spacers
Welcome along!
I've had spacers in the past and just found them to be an extra item to remove when working on the car.
I wouldn't bother either.
- Silver05
10 Jun 2020 15:22 #223442
by Silver05
Replied by Silver05 on topic Wheel Spacers
My thought was along the lines of improving the stance and road characteristics... is that not the case ?
10 Jun 2020 15:54 #223444
Stance is subjective and up to you. On road stability is not effected on a live axle vehicle by making the axle wider. The axle is always parallel to the road under anything like sane driving circumstances. To improve the stability you would need to increase the distance between the mounting point of the road springs and the centre of the car. And thus alter the roll centre of the vehicle, not as easy as it sounds.
The following user(s) said Thank You: Busta
Time to create page: 0.109 seconds
