Re:Kingpin
  • JP
30 May 2020 01:21 #223019 by JP
Kingpin was created by JP
Ok guys, I know that the Death Wobble thing has been beat to death & I've read the comprehensiv list of causes but I'm hoping someone with more knowledge of Jimnys will be able to give me an answer. I'm on the east coast of Canada so the shipping on parts is killer, not to mention the wait time,
I'm trying to cure Death Wobble on my 99 Jimny & I'm debating on ordering eather kingpin replacement kit or the caster correction bushings (I'm off work due to a back injury & can't afford both)
My question is this, can someone tell me if the kingpin barrings from my 88 Samurai will fit my 99 Jimny? Because I do have a new set of those on hand. But with my back being messed up I don't think I'm gonna be able to handle pulling it apart and putting it back together in 1 sitting, also if they won't fit it would save putting myself threw alot of unnecessary pain for nothing & taking it apart then waiting for parts isn't an option.
Thanks for any assistance everyone
30 May 2020 06:56 #223021 by mlines
Replied by mlines on topic Re:Kingpin
The kingpin bearings should fit, they are common across the entire generations of the Jimny, from LJ onwards!
The following user(s) said Thank You: JP
  • JP
30 May 2020 14:29 #223031 by JP
Replied by JP on topic Re:Kingpin
Thanks a million mlines, that's good, I did do some figuring & shopping about & between me & the wife decided that I've rebuilt pretty much everything else on my Jimny so I had might as well finish it & not have to worry about it while I'm recovering, so we raded the savings & ordered a frontend rebuild kit & 2.5 degree caster correction bushings, but with the wait times for delivery I'm still going to try the new kingpin barrings that I have
31 May 2020 14:23 - 31 May 2020 15:56 #223066 by Rabid Rhino
Replied by Rabid Rhino on topic Re:Kingpin
I see the BigJimny store sells Koyo. What are the bearing numbers ? (Cup & Race)
We can then order that number or cross reference it to other brands available in the free world. Even confirm if they are the same as Samurai.
My SJ413 (Samurai) axles had NTN 4T-30302 bearings: 15x42x13.0mm. Apparently this 30302 is also a Koyo number.
Samurai Koyo Bearing Number: 09265-15002.
Jimny King Pin Suzuki bearing number = SGA 09265-15002 ( mega zip says: 09265-15006-000) and cross referenced this comes up as Koyo HC 30302JR.
So in summary, same bearing numbers for Jimny as Samurai.
Now, onto the King Pins....
I went to megazip
1999-2011 Jimny JB33W KingPin Suzuki part number: 45610-63002-000
1986-1988 Samurai SJ413W KingPin Suzuki part number: 45610-63002-000
So they're the same parts.
I ordered 4 for $44 from suzukipartsusa.com
You can check the shim numbers.
Last edit: 31 May 2020 15:56 by Rabid Rhino.
Time to create page: 0.085 seconds
