Dual battery relay issues
22 May 2020 17:53 #222679
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Dual battery relay issues was created by me101
Evening all. Got the second battery wired up today, but got some issues if any one can shed some light. All seems fine, both batteries seem to be charging, but I have 2 problems. 1) The engine management light has come on, 2) The split charge relay starts to click when you rev the engine. Any one had this before?
Cheers
www.clsdoncaster.com/my-blog
Cheers
- Thank you received: 2004
23 May 2020 04:33 #222696
Replied by Lambert on topic Dual battery relay issues
I don't have a twin battery system but it should not do that. You have accounted for the Jimny being negative switching in how you have wired it up? It might help if you could do a napkin sketch of your wire connections then we can try and visualise the issue?
23 May 2020 05:23 #222701
by me101
Replied by me101 on topic Dual battery relay issues
Hi Lambert, I'm at work so can't do much, however, on this link there is a diagram (at the bottom of the page when you open it)
www.clsdoncaster.com/post/jimny-with-a-c...ing-a-second-battery
This is how I've wired it. Charges fine on tick over, but you can hear the relay going nuts when you apply revs.
Cheers
Cheers
23 May 2020 08:15 #222718
by RainerK
Replied by RainerK on topic Dual battery relay issues
Hello,
I used a Victron Energy Cyrix Relais to avoid this. They have a time lag for connecting or disconnecting the batteries based on the voltage and there is a D+ connection To the Cyrix to make sure that the alternator charges before the batteries are connected.
In my case, I connected a 40Ah LiFePo4 as primary battery and the lead acid as second battery. This works with the Cyrix-Li-ct.
I attach some pictures, including the plug where I got the D+.
This is not too expensive and works nicely. Hopefully this might help you.
23 May 2020 09:19 #222722
by me101
Thanks RainerK, don't want to be buying new bits if I can help it. This build is new parts only when I need to, rest is stuff out my garage! This was a relatively cheap (and I assumed simple) kit, just need to know if it is normal behavior or if I have done something stupid (again!)
Cheers
Cheers
The following user(s) said Thank You: Scimike
23 May 2020 10:26 #222725
by RainerK
Ok, then I cannot help you with hands on experience.
What I think happens is:
Something makes your relay close at under certain conditions - from what you write I would expect that this is based on the voltage of the main battery.
If the voltage gets over e.g., 14V the second battery is connected.
As soon as the second battery is connected, the Second battery starts charging and voltage drops below 14V because the second battery is not full.
The voltage drop makes the relais open again.
Then there is another round.
To prevent this the controlling of the relay would have to be adapted in either of 2 possibilities:
Either a time lag so that there is some time before the connection is opened again after closing this gives the second battery some time to charge. If this time lag would be 60 seconds, then the relay might switch on and off 20 times until the second battery is charged again. Or a bigger difference between the voltages that close and open the relay, e.g., close at 14V and open at 12.5V. In this case you would have to measure the actual voltages of your car with an empty second battery.
Or you do it manually with some switch. As soon as the main battery is charged you connect the second battery and disconnect it again after it is fully charged. This might be the easiest and cheapest solution - just do forget to disconnect when you turn off you car and run the fridge connected to the second battery over night.
Generally, make sure that the ampere rating of your battery connection relay is somewhat higher than the maximum ampere of the alternator because After connections the second battery there is not only the Energy of the alternator but also some from the main battery.
I hope this helps you a little.
Time to create page: 0.103 seconds
