Wheels and offset
  • Tintop92
18 Apr 2020 06:42 #221187 by Tintop92
Wheels and offset was created by Tintop92
Has anyone ever had problems with wheels rubbing to the track rod arms if not using spacers?
Got the car like that and trying to figure out how it works
Wheels are 15x7 will measure offset today
18 Apr 2020 08:14 #221190 by Riccy
Replied by Riccy on topic Wheels and offset
I found that the 15x8 steels I have with 0 offset catch the steering arm mounts if I dont use wheel spacers, are you sure the wheels are 15x7?
  • Tintop92
21 Apr 2020 20:36 #221361 by Tintop92
Replied by Tintop92 on topic Wheels and offset
Have measured the wheel it is 8inch altough on it is punched jj7x15 and 0 offset which I have to use 1inch spacer to clear
22 Apr 2020 04:03 - 22 Apr 2020 04:05 #221363 by Lambert
Replied by Lambert on topic Wheels and offset
Wheel width is measured between the mounting seat of the rim not the outside edge of the flange so it is possible for the j7 to be near 8 inches total width depending on how the flange is designed.
Last edit: 22 Apr 2020 04:05 by Lambert. Reason: Predictive text.
The following user(s) said Thank You: Tintop92
