Re:Re:Help
- Tonka2002
16 Apr 2020 20:02 #221143
by Tonka2002
Help was created by Tonka2002
Hi guys can anyone help iv got a 2002 Jimmy the n/s rear wheel bearing had collapsed iv change bearing ect n put back together but now the wheel feels like the hand break is stuck on as wheel is very stiff to turn iv checked shoes n hand brake and all is fine any ideas? I jacked the rear up and only one wheel turns should they both turn?
16 Apr 2020 20:59 #221144
Perhaps the shoe adjuster with the stepped end has been fitted the wrong way around?
- Tonka2002
16 Apr 2020 22:10 #221146
by Tonka2002
Replied by Tonka2002 on topic Re:Help
If the shoe adjuster is fitted wrong way round would that not make getting drum hard to get back on over the shoes plus the handbrake seems to work ok when you pull handle
- Jimx5
17 Apr 2020 04:30 #221149
by Jimx5
Replied by Jimx5 on topic Re:Help
Check your shoes are sitting in the slave piston slots correctly.
Easily done if slots are not sitting vertically or have moved slightly on reassembly.
17 Apr 2020 07:34 #221151
Replied by mlines on topic Re:Re:Help
Speaking from experience, I managed to do itTonka2002 wrote: If the shoe adjuster is fitted wrong way round would that not make getting drum hard to get back on over the shoes plus the handbrake seems to work ok when you pull handle
- Tonka2002
17 Apr 2020 09:24 #221155
by Tonka2002
Replied by Tonka2002 on topic Re:Re:Help
It all turns ok until you tighten the wheel spacer bolts then goes very stiff I definitely put the bearing on correct with spacer part to the outside so cant be that I'll have to have an other look at the adjuster arm end never had this problem last time
Time to create page: 0.098 seconds
