Advantages of rear disc brakes in a Jimny
02 Apr 2020 17:32 #220592
by Bosanek
Advantages of rear disc brakes in a Jimny was created by Bosanek
I see that replacing the rear drum brakes with disc brakes in a Jimny is a relatively popular modification.
What are the advantages for a normally (predominently on road and light to moderate occasional off road) used Jimny?
And what are the advantages for a Jimny used as an off road mule?
I don't think that a Jimny needs extra stopping power.
Is the modification feasible in vehicles equipped with ABS brakes?
Any disadvantages?
Any disadvantages?
02 Apr 2020 17:47 - 02 Apr 2020 17:52 #220595
by Scimike
Replied by Scimike on topic Advantages of rear disc brakes in a Jimny
They are certainly better if you wade in muddy water as you don't need to strip it to get the mud out after the event. They almost self clean and a simple hose with water and they are ready to go. They also "dry" quicker if you wade, which means you are back to 100% braking efficiency quicker.
That said you need to get in the mud a lot, normally the drums are ok, it's only the odd occasion it's full of stones etc.
Just my opinion based on my experience with my 100% drum braked Land Rover.
Mike
Mike
Last edit: 02 Apr 2020 17:52 by Scimike.
02 Apr 2020 18:22 #220601
by ahtr
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
Replied by ahtr on topic Advantages of rear disc brakes in a Jimny
Ease of maintenance a big plus point in my opinion. Easier to work on than drums, replacing pads/brake disc is a quick simple job rather than faffing with the springs and pins in a drum brake. Also a lot quicker to have a rear half shaft out and refitted.
Rebuild kit with new pistons and seals costs very little and is an easy half hour job (for the Renault calipers anyway).
Braking performance is improved, especially after fitting larger tyres. Handbrake definitely more positive and holds better.
I'd still run rear discs even if my Jimny didn't see any dirt.
- Thank you received: 1999
02 Apr 2020 19:00 #220605
Replied by Lambert on topic Advantages of rear disc brakes in a Jimny
I like the idea of rear disc brakes for more stopping when towing but it would be another modification to inform the insurance of and really while it would make maintenance easier I haven't had to do anything of any consequence to the rear brakes in 9 years on Dreadnaught.
Time to create page: 0.355 seconds
