Re:Jimny off road capability - a critique
29 Mar 2020 15:27 - 29 Mar 2020 15:29 #220429 by 300bhpton
So I haven't yet done lots of off roading in my JB74. But I've used it a bit and thought I'd offer up some opinions.
Apart from some diff guards, my Jimny is 100% bone stock. I have also only driven it on one type of off road terrain. The terrain is semi-technical with a fair number of axle twisters and areas to test approach/departure angles.
Basis for comparison:
I have been driving off road in one form or another since the age of about 11. Mostly in Land Rover's, although a few Jeeps and other vehicles thrown in the mix also. I grew up on a farm and learnt to drive in a Land Rover in a field. But for over 20 years I have also competed in off road trials competitions.
As a direct comparison today I was comparing to my 88 Land Rover, as it has the same wheelbase as the Jimny, open diffs, no TCS. It has a wider track and slightly modified suspension. But nothing overly radical.
Good points:
For a bone stock vehicle there is no denying the Jimny can cover the terrain. To call it a mountain goat is probably pretty fair. It doesn't get stopped, not even on road biased tyres. And overall feels moderately good in stability and control. And also is very nimble and manoeuvrable with fairly good steering lock.
The TCS massively enhances its capability.
Bad points:
It doesn't go slow enough in low 1st for technical off roading. It is also very easy to stall with the 5-speed manual. This happens when trying to go at tickover speeds. And when using the TCS. While the TCS is hugely impressive, it does require you to use some throttle, which can make you lurch over obstacles and crash down fairly hard when you have a wheel high in the air. For me the vehicle just wants to go a little too quickly for the terrain I'm on, which makes it harder work and less relaxing.
Part of the issue is the reliance on the TCS system. The JB74, despite being a live axle 4x4, still seems to want to lift a wheel quite frequently. Having watched lots of videos on YouTube of the new Jimny, you can clearly see this. The stock suspension setup just lacks the flex for this kind of off roading. However the all of the aftermarket suspension kits I've seen on YouTube seem to transform this capability. So I'm looking forward to upgrading mine.
I also found the front approach angle to be somewhat of an issue and have thus far scraped/impacted the front bumper into the ground. As well as the super silly ultra low front recovery point.
Last edit: 29 Mar 2020 15:29 by 300bhpton.
29 Mar 2020 15:37 #220430 by DAGZOOK
BHP I'd love to see someone go all out and install a fully functioning 60mm+ Jimny lift kit (As the YouTube video you shared demonstrated). toughdogdealer.com.au/collections/suzuki-jimny-2019 . I've got family in AUS all too tempting :silly:
29 Mar 2020 15:43 #220431 by sniper
I only drove the 19' model car for a short time off road in the Lakes in that small time, I found that you need to surrender to the electronics.
Just like any new 4x4 the gizmo's will get you there, it won't look skilful, it won't be full of grace and elegance but mostly it will get you there. Gizmo's work and make the car appear to stutter and jerk, but that's how they work. Surrender all but directional control and the car will do it..
A complete novice driver took it over Gatescarth and Parkamoor with no problem...
sniper
  • Jasongds
29 Mar 2020 19:57 #220445 by Jasongds
Replied by Jasongds on topic Jimny off road capability - a critique
Where a Jimny will run rings around a Land Rover or any bigger 4x4, ( I also have a G Wagon) put them on a wet field try to go up a slope, all the big stuff that weight gets right in the way. Mind you original LJ80 /50 super light, 600kg?
29 Mar 2020 21:42 - 29 Mar 2020 21:44 #220448 by crash486
Absolutely agree about hill descent and overall gearing. Too fast downhill and very hard to crawl forward over obstacles.
Doing rock ledges/ steps I've found to be quite challenging to get throttle and momentum just right.
One friend had a very "interesting " event. He was crawling up a 15deg incline, popped up a step with a tiny bit too much throttle and... pivoted the Jimny vertical on the back wheels. It hung there for a few seconds before settling safely down.
A lower gear would have been of benefit as would a longer wheelbase but it is what is.
I am constantly amazed at what this little vehicle can achieve.
It has limits like all vehicles but they are currently way beyond my skill level, for which I am grateful.
crash486
Last edit: 29 Mar 2020 21:44 by crash486.
30 Mar 2020 04:27 #220454 by Lambert
It's sounding like the overall gearing hasn't been changed to accommodate the 195.80 tyre instead relying on the increase in power from the 1.5? My Dreadnaught on her 205.70 tyres is not over geared and will shuffle along in low 1st at tickover quite happily. Compared with the old Cherokee sport or even the grand vitara Dreadnaught is actually very low and really controlled.
