Snorkel template!
- Evzlid
25 Mar 2020 17:50 - 25 Mar 2020 17:52 #220261
by Evzlid
Snorkel template! was created by Evzlid
Hi guys, I’m new to the forum but have used it many times to help on my jimmy! Thanks for all your great advice throughout the forum! In these lockdown times I was going to try and fit my snorkel I have had for years but I don’t have a template! Does anyone have a copy of one or any advice for me!
Thanks in advance!
Andy
Thanks in advance!
Andy
Last edit: 25 Mar 2020 17:52 by Evzlid.
25 Mar 2020 17:56 #220262
by Scimike
Replied by Scimike on topic Snorkel template!
Can't help with template, but I assume different snorkels exist, so which make do you have?
This may help others or it's a daft question on my part.
Only advice is measure many times and cut once, especially as the template is unknown until it's fitted.
Good luck
Mike
Good luck
Mike
- Evzlid
25 Mar 2020 18:04 #220263
by Evzlid
Replied by Evzlid on topic Snorkel template!
Hi mike, thanks for the reply! It’s the long style type with Jimny on it! I’m mostly unsure of the position it would go! The pipe that connects to the air filter is angled making it a bit harder!
Thanks again!
Andy
Thanks again!
Andy
25 Mar 2020 22:37 #220269
Replied by Daniel30 on topic Snorkel template!
Haven't got the template any more, but I don't know if pictures of mine with measurements would be any good?
Sounds like it's the same as mine.
And welcome to the forum
25 Mar 2020 23:55 - 25 Mar 2020 23:55 #220270
Replied by yakuza on topic Snorkel template!
How wierd and strange. Was in my garage earlier tonight and looked at my used tjm airtec snorkle, and googled a bit to try to find a template. Now a few hours later it is the freshest topic. Coincidence!
Anyways I only found the install description for the gen4 snorkel on my small phone screen, will look harder tomorrow for the gen3.
This is also a good idea:
www.bigjimny.com/index.php/forum/6-jimny...rkel-template#167581
Last edit: 25 Mar 2020 23:55 by yakuza.
- Max Headroom
- Banned
- Thank you received: 216
26 Mar 2020 06:37 - 26 Mar 2020 06:37 #220272
by Max Headroom
Replied by Max Headroom on topic Snorkel template!
A BIGJimny Welcome from the Cotswold Hills, Evzlid!
I'm with Scimike on this; measure umpteen times and cut once. Alas I can't help with a template either.
There are some other Jimny rescources you could try such as Facecrook or see if there are any templates to download from other companies although that won't neccessarily be helpful and could ultimately cause a mistake. Other than that it's probably going to be a lot of maths and dead-reckoning to get the hole right.
Did you ever have the template and mislaid it? If so - get searching! Good luck
Last edit: 26 Mar 2020 06:37 by Max Headroom.
Time to create page: 0.117 seconds
