Camshaft position sensor location
- AH1992
15 Mar 2020 22:41 #219902
by AH1992
Camshaft position sensor location was created by AH1992
Hi, I am trying to locate the cam position sensor on, if there is one fitted, on my daughters Jimny, M13 VVT DOHC engine.
I can find the crank sensor below the alternator OK but there is no cam sensor fitted at the front of the engine as I have seen on various photos.
There doesn't appear to be one fitted at the rear either, so I wonder does this variant have one?. Any guidance appreciated.
- CC Baxter
16 Mar 2020 08:48 #219913
by CC Baxter
Replied by CC Baxter on topic Camshaft position sensor location
Bump. A photo of it's exact location would be nice. Anybody?
Chris
Chris
- CC Baxter
16 Mar 2020 20:15 #219951
by CC Baxter
Bump!
17 Mar 2020 07:46 #219970
by kirkynut
Replied by kirkynut on topic Camshaft position sensor location
Front of the engine on the right hand side at the top as you stand in front of it staring at the engine on my M13a. I need to see a VVT engine to know if they moved it.
- CC Baxter
17 Mar 2020 09:36 #219974
by CC Baxter
17 Mar 2020 09:46 #219975
by facade
Replied by facade on topic Camshaft position sensor location
The VVT moved it to the back of the engine on the inlet cam (because the phaser is at the front) so the sensor is at the back on the inlet side, I think it is on the underside of the cam, forwards of the EGR valve. Left side if you are at the radiator looking towards the windscreen.
The following user(s) said Thank You: CC Baxter
Time to create page: 0.099 seconds
