Buying First Jimny
- ColinTheViking
29 Feb 2020 00:12 #219210
by ColinTheViking
Buying First Jimny was created by ColinTheViking
Hi guys,
I’m currently in the market for a Jimny budget approx 4k, I’ve seen a 2007 with 49k miles and am going to be checking it out for issue and rust but it looks promising at the moment, I have been told the 07,08 models have gearbox issues and I was wondering how severe this could be and if it is really common? Whilst I’m at it is there any other advice to know about for this model year?
29 Feb 2020 00:38 - 29 Feb 2020 00:39 #219211
by Scimike
Replied by Scimike on topic Buying First Jimny
Hi Colin,
It's the R72 gearbox used from about 2005 until the end of production in 2018 that gets a bad wrap. On or after 2009 Suzuki started to fit a sealed bearing in place of a previous open type, it's this bearing that can fail. It is a reported common failure mode of this gearbox from 2005 to or after 2009, but actually how many have failed out of the Jimny G3 produced between these dates is harder to quantify. It was never, as far as I am aware, a recall issue, but Suzuki must have seen more failures than on earlier gearboxes for them to change the part.
I believe the R72 is still used in the generation4, so it can't be all bad.
I have a 2009 with unknown bearing type, but so far (11 years and counting) it's still working like a new gearbox, so I tend not to be too concerned.
They can be fixed and your only other alternative is to spend extra ££££ to get a vehicle 2010 on, just in case the gearbox fails, or buy a cheaper one and keep 800 in the bank just in case.
I'll say it again, RUST is the big issue and can cost a lot more than the gearbox to fix correctly. Also the vacuum hub system can stop working (due to rusty pipes) or lack of use, so check they engage. Of course all the gears should work with no grinding or crunchy sounds as you change or drive along.
Don't be put off, they are actually very reliable vehicles, we tend to highlight any issues that deviate from perfect.
They are great fun.
Mike
They are great fun.
Mike
Last edit: 29 Feb 2020 00:39 by Scimike.
- Max Headroom
- Banned
- Thank you received: 216
29 Feb 2020 01:38 #219213
by Max Headroom
Replied by Max Headroom on topic Buying First Jimny
I'd like to echo all of what Scimike says here.
I have the dreaded R72 box in mine and so far (touch wood) it has been fine. I don't know it's history, but as a small precautionary I drain and flush it at every annual service
29 Feb 2020 08:41 #219216
by Scimike
I also change the gearbox and axle oil on a scheduled basis, but then I tow a lot so I figure it's getting a harder life and the oil is cheap enough.
Gearbox aside
I forgot to say check the condition of the kingpin bearings or ask when they got changed. At 2007/2008 I would have expected them to have been replaced or if not starting to fail. You can usually feel any free play in the front wheel. Wobble at 45mph or oil around the swivel can be a sign they are failing (but not guaranteed), but still something to check.
Again don't panic, easy enough DIY fix at £45 per side in parts, but factor labour ( 2hr a side ) if you don't intend to fix it yourself.
Hope it turns out to be a good one for you.
Mike
Gearbox aside
Mike
01 Mar 2020 06:53 - 01 Mar 2020 06:53 #219232
by kirkynut
Replied by kirkynut on topic Buying First Jimny
Welcome along!
In relation to the gearbox question, as they've said above.
I personally prefer the lever transfer box as you're in control of putting it in 4wd with little to go wrong but you'll look at a lot of rusty ones before you get a good one. These are pre-2005 and pre the gearbox with the issues.
Last edit: 01 Mar 2020 06:53 by kirkynut.
Time to create page: 0.082 seconds
