Rear winch
  • Pommy
25 Feb 2020 18:35 - 25 Feb 2020 18:39 #219065 by Pommy
Rear winch was created by Pommy
I own a 2002 Jimny and want to put a winch on the rear sometimes it’s better to backwards rather pushing my luck on wet ground. I’m looking for advice on mounting I’ve tried to find pictures of others that show a little detail on how they have been fitted but they are few and far between. I do have a winch mounted on the front. I’d thought maybe the answer would be to fit tow bar with 50 mm receiver ! Any suggestion gratefully accepted
Last edit: 25 Feb 2020 18:39 by Pommy.
25 Feb 2020 18:41 #219066 by Lambert
Replied by Lambert on topic Rear winch
I would think that the best way would involve customizing the boot floor where the jack used to go and making a bolted in bracket between the chassis rails that would maintain the departure angle.
The following user(s) said Thank You: Pommy
  • X8GGY
25 Feb 2020 20:11 #219072 by X8GGY
Replied by X8GGY on topic Rear winch
Mine was mounted on a modified tow bar, so that it fitted nicely in the "number plate recess" area, but an Offroad Armoury metal bumper -
27 Feb 2020 10:35 #219146 by kirkynut
Replied by kirkynut on topic Rear winch
X8GGY wrote: Mine was mounted on a modified tow bar, so that it fitted nicely in the "number plate recess" area, but an Offroad Armoury metal bumper -
Dave's rear winch installation is the best I've seen. You don't want to have to lose your rear box on the exhaust unless you like it noisy and this seemed to be the best solution.
Time to create page: 0.099 seconds
