Engine fault codes please help!!!
- Olliecarr25
23 Feb 2020 13:27 #218940
by Olliecarr25
Engine fault codes please help!!! was created by Olliecarr25
Hi there I have a 2002 Suzuki jimny which I have just put a new engine in as the big end went on the old one after the installation of the new (second hand) engine I have a couple Fault codes I will Attach images of them and any help will be really appreciated thanks
23 Feb 2020 13:42 #218941
Replied by yakuza on topic Engine fault codes please help!!!
You should check the connection then first. Even reset the errors and see if they come back as things might come around after the engine swap..
I moved most sensors over from my old engine to the new one as the ecu worked with the old ones and gave no errors before i switched engines..
the o2 sensor number one is on the exhaust manfold on my car, not sure of your car has two of these being it is 2002 but i think it is the same.
The no 1 sensor is before the catalytic converter and the no 2 sensor after the cat. under the car.
both connections on the wiring loom at the firewall behind the engine on the exhaust side.
I had to change one o2 sensor after my engine swap, dunno why..
knock sensor is on the side of the engine, sorry i cant remeber wich side right now.
The following user(s) said Thank You: Olliecarr25
- Olliecarr25
23 Feb 2020 14:13 #218942
by Olliecarr25
Replied by Olliecarr25 on topic Engine fault codes please help!!!
Thanks for your help I wiggled the connections and reset it now it’s only found 2 faults however they both look to be the same this is the Faults I am left with 02 sensor heater circuit bank 1 sensor 1
24 Feb 2020 08:25 #218991
by kirkynut
Replied by kirkynut on topic Engine fault codes please help!!!
I'm not sure how the O2 sensor was fine on your old engine but not with this one as you've not touched it to change the engine!
I think I'd be tempted to drive it as it is for a week after disconnecting and re-connecting the O2 sensor plug. Then if it's still the same after resetting, change the O2 sensor.
24 Feb 2020 08:32 #218993
As kirky says.
You may have a sensor from your donor engine?
I got a 99 baleno sensor on mine now, think they are all mostly the same when the wire count is the same. Suzuki is clever to reuse the same parts.
Time to create page: 0.103 seconds
