Battery isolator question...
  • gusthegorilla
08 Feb 2020 18:06 #218173 by gusthegorilla
Battery isolator question... was created by gusthegorilla
Hi, guys,
Recently, I purchased a 'new toy' from a hugely respected Forum member, which came with only one key, the non- remote version.
Timpsons are going to resolve this problem for me in the coming week !!!
However, whilst I've been dwelling on the subject of keeping my new toy all to myself, I began thinking about fitting a battery isolation switch ( which I just happen to have !).
What I would like to know is this....which side (positive or negative) is it best to break into, and do I need to provide any additional electrics to keep minor services powered up (eg. the radio code, ECU....) ??
Forgive my ignorance...mechanically, I'm a genius....electrically, I'm a buffoon !!!!
Cheers,
Gus
08 Feb 2020 18:45 #218174 by jackonlyjack
find a fuse what stops the car from starting
Preferably one that don't effect radio settings
The do something like this Mate
  • gusthegorilla
08 Feb 2020 18:54 #218175 by gusthegorilla
Replied by gusthegorilla on topic Battery isolator question...
You mean break into the power line to the starter, Jack...??
Presumably, this would leave everything else intact..?
08 Feb 2020 19:09 #218176 by jackonlyjack
I would have more idea if i had a wiring diagram
So if you can find a fuse that feeds the ignition
just cut the wire and send it through your isolation switch
easy to pull out the fuse to find a suitable wire
just make sure it does not effect central locking so you can still lock it :)
The following user(s) said Thank You: gusthegorilla
  • gusthegorilla
08 Feb 2020 20:07 #218179 by gusthegorilla
Thank you, Jack, that makes sense....I'll have a look in the morning, storm permitting !!
08 Feb 2020 20:25 #218181 by jackonlyjack
Here's one of many of my devices
Home made of course
Doing a rear door handle delete next
Time to create page: 0.094 seconds
