Key replacement
08 Feb 2020 11:41 #218167 by Lambert
Key replacement was created by Lambert
Whatcha. My remote key frame has snapped. I am looking at either a direct swap or one of the cheaper flip keys. Has anyone swapped to a flip and if so was it worth the effort does it work well etc?
09 Feb 2020 14:22 #218212 by Scimike
Replied by Scimike on topic Key replacement
Not done it myself, but I have looked at the cases on eBay for about £6.99 ish.
The feedback (on eBay) suggests they work but the case quality is not on the high side. I doubt this matters that much if it's a working vehicle, so on paper it looks like a good idea. Can't find any feedback on the durability of the case, but it's not expensive.
You could be the first to try the flip case on here, if you do interested in what you think of them.
Mike
09 Feb 2020 18:42 #218235 by Lambert
Replied by Lambert on topic Key replacement
Yes I suspect you are right about the material quality and durability but having paid 6.35 for a flip and normal blade key I have options going forward that haven't broken the bank.
16 Feb 2020 09:16 #218578 by Lambert
Ok so I have now got my flip key in service and it is good. With one minor caveat, the new button rubber that is supplied with the blank is fractionally too deep to be used in the existing remote clamshell which is unfortunate for me as my button pad while functional is quite worn. Other than that the blank was easily indexed to be cut and the body seems to be suitably robust and clearance of the ignition is spot on. Very happy.
20 Feb 2020 07:26 #218792 by Bosanek
Replied by Bosanek on topic Key replacement
If you want a high quality key case, why not buy a used key from a dead Jimny from a vehicle junkyard, and swap over your key and electronics into that case?
20 Feb 2020 07:32 #218793 by Lambert
Because on mine at least the blade is bonded to the grayish centre structure of the body. And my blade was also worn by about half a millimetre on the serrated edge compared to the unused spare which amazed my locksmith that it was still functional.
Time to create page: 0.108 seconds
