Diff drain plug washer
  • 2013gary
21 Jan 2020 14:32 #217483 by 2013gary
Diff drain plug washer was created by 2013gary
Hi all,
A few months ago I changed the diff oil in my 2003 Jimny. I recently noticed that there's a slight leak coming from the drain plug. I was unable to find a washer and - if I remember correctly - I read that it was okay to re-use the old one, so that's what I did.
Now it looks like I'm going to have to change the washer, does anyone know where I can get one the correct size? The Big Jimny shop sells them for the filler but not for the drain plug.
Also does anyone have any magic tips for changing the washer with minimal spillage - or am I better off draining it and refilling it? Refilling was a bit of a pain so I'm not looking forward to it.
Many thanks,
Gary
21 Jan 2020 16:07 #217488 by Lambert
Replied by Lambert on topic Diff drain plug washer
There is no clean and easy way round it I'm afraid. And yes it's better to do it as a change of oil than trying to get the plug out , your finger in the hole, put a washer on with the other hand and then get the plug back in. Just not worth the squeeze.
21 Jan 2020 18:07 #217494 by jackonlyjack
Replied by jackonlyjack on topic Diff drain plug washer
It has a washer :woohoo: here's me thinking mine had a tapered thread
never seen a washer or used one or sealant
just put it back in FT :laugh:
21 Jan 2020 18:43 #217495 by Lambert
Mine has a sort of plastic washer thing which I guess I should probably replace with the next oil change?
21 Jan 2020 19:42 #217500 by gv42
Replied by gv42 on topic Diff drain plug washer
I used , the BLUE, sealant on it
21 Jan 2020 20:26 #217502 by Scimike
Replied by Scimike on topic Diff drain plug washer
Even though I have replaced all the fluids I can't for the life of me remember if it had a washer or was a tapered plug???
Still it matters not for on either type I always put a thin smear of blue sealant as gv42, as a back up just in case, always worked for me. Blue hylomar is my preferred stuff, with this method my 1960 series 2 is still on the original axle plugs and does not leak. -. Well the axle plugs don't, pours out of ever other orifice. :laugh:
