Tie Rod Ends
- Smith335
01 Jan 2020 01:19 #216872
by Smith335
Tie Rod Ends was created by Smith335
Hi Everyone,
I was hoping to seek clarification of the type of thread in the four of the tie rod ends that make up the steering component.
Would I be correct in assuming that two of the four are reverse threads?
I am looking at replacing all off them in one go rather than removing them individually and confirming their thread.
Thanks for any assistance you can provide.
Cheers.
Cheers.
- Thank you received: 2004
01 Jan 2020 05:07 #216873
Replied by Lambert on topic Tie Rod Ends
Yes you are correct. One left hand threaded and one right hand threaded per steering bar. The bigjimny store has them at a good price.
The following user(s) said Thank You: Smith335
01 Jan 2020 11:08 - 01 Jan 2020 11:09 #216877
by facade
Replied by facade on topic Tie Rod Ends
As Lambert confirms, they are opposite hand at each end of the rods, so rotating the rod moves both ends out or in at the same time, lengthening or shortening the assembly.
If they were the same hand thread, rotating the rod would just move it off one joint and onto the other, and it wouldn't adjust anything.
Last edit: 01 Jan 2020 11:09 by facade.
- Thank you received: 706
01 Jan 2020 12:12 #216878
Replied by jackonlyjack on topic Tie Rod Ends
Also you may need new nuts for the end's
I have always had to cut the old nuts off
- Max Headroom
- Banned
- Thank you received: 216
13 Jan 2020 21:30 #217243
by Max Headroom
Replied by Max Headroom on topic Tie Rod Ends
I'll second that about the nuts - very worthwhile replacing them at the same time as the rod ends - mine seemed okay until I tried to turn them several turns - only then did I find the threads were shot.
Time to create page: 0.096 seconds
